Results 1 to 16 of 16
Thread: Please help *no EQ Ratio bing logged
    Tuner nathanhine1977's Avatar
    Oct 2019
    Darwin Australia
    53
    Hi
    Can someone please help me under stand why im not logging EQ ratio?
    Thanks.No EQ ratio.hpl
    13,614
    I see it in the channels list, so to me it's being logged.
    Oct 2019
    Darwin Australia
    53
    its not being displayed?????
    7,989
    It is being displayed in the channels list, and a log file by itself is nothing but the channels. If what you mean is that it's not showing up in whatever graph you made, then for other people to see that you'd have to save your current graphs layout and then upload that graphs.Default.xml file.
    Oct 2019
    Darwin Australia
    53
    Grapg layour not readinf EQ Ratio.Graphs.xml
    Can you please look at the graph lay out.
    Thanks Legend.
    7,989
    Way way too many graphs. You need specific groups of graphs for doing specific things, don't have every graph you've ever thought up that might be useful one day and load them all at the same time all the time.
    Which one of the ~30 graphs isn't doing what you want it to?
    Oct 2019
    Darwin Australia
    53
    its the 3rd from the top,
    All was good until I cleaned out mu laptop, then re install HP Tuners and forgot all the steps that went into tuning setup, So I have forgot what is need to log EQ error ratio for SD tuning, ECU is E40
    7,989
    Oct 2019
    Darwin Australia
    53
    Thanks.
    7,989
    Yes if you pick a different thing it will not look the same.
    Oct 2019
    Darwin Australia
    53
    Im trying to log the difference from commanded Lambda to actual lambda
    Oct 2019
    Darwin Australia
    53
    In thishttps://drive.google.com/file/d/1fXE...ew?usp=sharing old file every thing shows up, but when I open up a new log, for some reason it is not working.
    Oct 2019
    Darwin Australia
    53
    15t Oct 2022cruise fuel.hpl
    With this old log this is no problem,
    I can see in this log that the Transform data is there, but in today's log, its does not show the info
    7,989
    Oct 2019
    Darwin Australia
    53
    Still trying to work out why I cant see the Percentage of Lambda off from commandedSunday 12th May 2024.hpl
    Jul 2020
    VIC Australia
    1,199
    Give this math parameter a whirl. Set unit as percent
    100 * ([40001] - [50118.238]) / [50118.238]
