Results 1 to 7 of 7
Thread: Edge Sport 3.7L support?
    I see HP supports the Ford Edge 07-14 and says 3.5L, it also supports the MKZ with the 3.7L, but does it support the Edge Sport with the 3.7L? My wife has a 2014, I had tuned her 2013 with SCT and wouldn't mind using HP on her 2014 if it will work. It should be the same processor as the 3.5L engine.
    Should I simply just read the vehicle and see if it opens up properly?
    Oct 2007
    Crawfordville, FL
    2,464
    Read it, and send the file to support.
    It did not auto select the pcm type. I tried reading it as an ESYS processor. It completed the read but said checksum validaition failed. Was that the correct type of processor?
    Oct 2007
    Crawfordville, FL
    2,464
    Pretty sure that one is an ESYS. If it read, that is a good sign. The checksum validation failed is normal for a OSID we do not have defined. You probably also got a definition failed to load error. Save the file and send it to support at hptuners dot com and it will be put in queue for adding.
    Eric Brooks
    HP Tuners, LLC
    Any status update on this? I just am looking for some time frame window so I can plan things on my side.
    Oct 2023
    Any update on this?
    Nov 2023
    Mexico
    9
    Quote Originally Posted by Sweet35th View Post
    Use the Beta version of VCM Editor
