Results 1 to 9 of 9
Thread: 2017 Dodge charger rt 5.7 having a huge headache with hc injectors
    Aug 2023
    9
    Have a dodge charger 2017 RT
    Longtube BBK headers
    6.4 intake manifold with SRV windows switch control
    Proflex commander pro
    Jlt intake
    Hc throttle body
    And last mod was hc injector
    After the installation and put rhe hc stock injectors parameters
    The car in idle and low rpm or when i release the gas pedal the car stalls..
    I have tried til now
    Ltft and stft
    Injector pulse and volts
    Idle torque
    Fuel trim
    Fueling with neural network.
    And still having the same problem?
    Tuner in Training jefo's Avatar
    Jul 2022
    37
    Where did you get the injector parameters? If from a stock hellcat tune, the parameters will be different due to different fuel pressure (Hellcat runs much higher pressure than the RT 58psi)
    2006 AWD 300C Turbo - stock 5.7, stock NAG1
    10.8@126mph on 12psi - WatTuned
    Aug 2021
    Yorktown VA
    203
    Post your tune and I can tell you what needs to be adjusted
    2016 Ram CCSB Forged NA 396ci Stroker
    +2.5cc Flat/Dome Mahle Power-Pak Forged Pistons w/13.2/1 CR on E85
    Forged Manley 4.05" Stroke Crank/Speed Master Valvetrain
    Race Ported Eagles/Titanium 2.12"/Titanium 1.62" Valves
    Custom Cam 235/249 .629/.629 111LSA 110ICL+1Adv
    Ported Holley Hi-Ram Intake/NXpress Hi-Ram NO2 Plate kit w/250 Shot(4 sec)
    Tx Spd 2" Long Tubes/Active Viper Hood/2-Step
    ATI SD w/15% UD/Dual 450 Pumps/Fuel Cell in Bed/Demon 700cc Inj
    3800 stall/Det Tru-Trac/410 Gears
    Aug 2023
    9
    here is my tune
    I tested many things and changed many stuff
    Aug 2023
    9
    I changed the LTFT B1, B2 and STFT B1, B2
    also LTFT Bank1
    Modified Inj PW vs Fuel Mass
    Fuel mass vs Inj PW
    Inj PW Min
    Inj PW Offset
    Start Up Base...
    tried everything that I know and no luck...
    Jul 2022
    37
    Where did you get the injector data? I would confirm this is correct first
    Aug 2023
    9
    I got from a hc injector stock data sheet
    since is the stock hc injectors
    and start from there
    Aug 2021
    Yorktown VA
    203
    Give this a shot and see if this helps at all....
    Aug 2023
    9
    I will try next week cause I have to reinstall the injectors
