Results 1 to 5 of 5
Thread: 2020 6.7 base tune
    Nov 2023
    2020 6.7 base tune
    New to this and seeing as the 2020 ecm cant be read how do we get base files?
    Aug 2023
    canada
    51
    yes you should be able to.
    Apr 2021
    38
    After you have the ECM unlocked by HPTuners, when you try to read the ECM you will be supplied with a virtual read for you to edit. Keep in mind that you will not be able to delete any emissions items with using the basic VCM Editor software.
    Nov 2023
    Quote Originally Posted by slimmons2009 View Post
    Ive disabled the codes but still getting the reduced engine power on the dash. So Im confused on it.
    Sep 2021
    35
    Quote Originally Posted by fordman2121 View Post
    Disabling emissions related codes will not remove the subroutines that control the emissions. If you're trying to delete simply by disabling codes, it will not work. You'll need to find someone to revise your base tune to disable those areas.
