Results 1 to 6 of 6
Thread: 2023 Scatpack with hellcat injectors
    Ok so im working on a 2023 Scatpack with built 426, injectors have been changed to hellcat injectors.
    is there an actual file with same OS that i can use to update my injector data, i found plenty stock 2016 hellcat information but i see the tables are slightly different when it comes to the INJ PW vs Fuel Mass and Fuel Mass vs. Inj PW
    Im coming from GM side so dont burn me too much, this is my first mopar.
    5BA8
    3,629
    Short answer is no. Break out the calculator. Start crunching numbers. Make it fit.
    email=[email protected]
    I dont have a log on me yet but can someone review my injector data to ensure it is correct
    thanks in advance.
    bump
    Feb 2024
    34
    Quote Originally Posted by tana99ss View Post
    bump
    hellcat data will only get you so far because, they have a completely different fuel system so it wont be accurate,
    There is 5 different HC Injector Characterizations depending on what fuel system they are in. And I created a 6th one for the stock non HellCat fuel system. Took me about 30 tunes and logs to get it correct, so if you know what you are doing, you too can come up with one that works.
