Results 1 to 20 of 21
Thread: ECU With "y" VIN and Serial
    May 2024
    Florida
    6
    Good Morning All
    New to the forum and HP Tuners.
    I have a 1998 LS1 W/4L60E swapped into a 1985 Camaro Z28. I am using an Ebay Harness that was for 99+ (I.e. NOT re-pinned to use the original 98 ECU).
    My current ECU is a P01 ECM with operating system 12212156, and was tuned by a third party.
    This setup has run great for about 200 miles, but I decided that I'd like to be able to change Fan On/Off Temps and some other small settings, so I purchased an MPVI3 with 2 credits. When I got as far as writing a simple change, I found that my existing ECU shows a VIN with "yyyyyyyyyyyyy" (with small dots above the "Y"'s) and the same for the serial number. I get a License selector screen on HP Tuners, and "Do Not License" is my only checkbox.
    I have researched this in other similar posts, and it seems that even if I hit "OK" on the dialog box, I won't be able to license this ECU in order to correct the problem, rather the only fix would be to flash the ECU back to GM Stock and then License and rewrite my existing file with Tuners.
    I don't have access to a GM tool, so I'm thinking I may just purchase another stock ECU using my current backed up file. So now for the question: The only ECU I can source locally is a stock software version 1200411 out of a 2002 4.3L V6 4L60E Silverado. Will this ECU work from my existing tune being it is a Gen3 Red/Blue?
    Thanks in advance. Screenshots below of my current ECU:
    https://drive.google.com/file/d/1AsC...ew?usp=sharing
    https://drive.google.com/file/d/1Ffr...ew?usp=sharing
    7,950
    Attach files here, not offsite. It's free and no one can ever take them offline except HPT themselves.
    PCM is corrupt. You can try a dealer-type reflash with dealer-type tools (Tech2/MDI + SPS), nothing else is going to fix it and even that may not.
    7,950
    https://www.ebay.com/sch/i.html?_nkw...programmed+vin
    Much cheaper than all the stuff you'd need to buy to flash this one PCM this one time that may not even work, probably also cheaper than paying someone who already has the tools to flash the one you already have.
    405
    2,368
    The PCM was probably a reman. They all seem to have those VINs and serial numbers. Also if you put your location in your profile there could possibly be someone local to you that could help with a PCM.
    May 2024
    Florida
    6
    Thanks for the advice! Do you suspect that the 12200411 will work with my setup, given my current ECU's version is 12212156?
    Thanks again.
    May 2024
    Florida
    6
    Thanks - I have updated my Profile.. Appreciate the heads up.
    7,950
    Quote Originally Posted by Actaeon View Post
    Thanks again.
    12200411 is the Service Number, which describes the hardware inside. 12212156 is the operating system (the software that runs on the hardware). Any PCM with the service number of 12200411 can be programmed with (without bricking) any operating system from any other vehicle that used that same service number.
    405
    2,368
    What is the 1200411 PCM out of the 2002 4.3L V6 4L60E Silverado going to cost you?
    May 2024
    Florida
    6
    The one I can source locally is 75$.
    May 2024
    Florida
    6
    Awesome - Thanks again for the info..
    405
    2,368
    That is way too much for a 0411 PMC. And be aware no matter what you do it is going to cost 4 credits to program it. Then you are spending $275.
    May 2024
    Florida
    6
    Out of curiosity, why 4 credits instead of 2?
    7,950
    Because it's 2 credits for a PCM you've never written to before and 2 credits for the file you found someplace that came out of somebody else's PCM (yours is corrupt and can't be written to the new PCM).
    Sep 2021
    Kentucky
    521
    https://www.ebay.com/itm/11607242151...mis&media=COPY
    Here is one setup and ready to go for the swap.
    405
    2,368
    And he runs the risk of getting the same thing he has now. Looks like a reman. Better off getting one out of a vehicle.
    Arizona
    508
    0411's and all other LS style computers are $25 at the local part yards around me
    There is always the possibility that the unknown 3rd party who originally tuned this used a non-commercial product like pcmhammer or lsdroid and just messed up the vin. It is not 100% sure that the file is actually corrupted to an unusable state.
    7,950
    So you're saying that someone edited the VIN/serial to intentionally make it look just like one that's got a problem?
    1999 Camaro A4 1455335759.hpt
    This one appears to be stock (https://tis2web.service.opel.com/tis2web/).
    Not intentionally, but it would be a very easy mistake to make editing a bin with tunerpro, and especially if using an "almost" correct xdf.
    405
    2,368
    VIN, yes, serial, not likely. Like I said that is very common to see that on parts store remans.
