Results 1 to 19 of 19
Thread: 6l80e 2010 (t43)
    May 2024
    18
    6l80e 2010 (t43)
    Hello, i have a T43 tcm i need to get working with a E92A (2017+) ECU. How can i find what OS is compatible, and where do i download them for HP tuners? is all T43 TCM made the same so i can flash the latest OS to it?
    Currently i get the dreaded U0100 and U0101....
    Kind Regards Tonny
    May 2024
    18
    ECU OS is 12677878 and TCM is 24254909
    Jan 2004
    Perth - Western Australia
    280
    your probably gonna need to find a factory car that had those options & perform a full flash of the tcm.
    Otherwise learn to delve into the code to find the CAN broadcast parameters & add the options to modify the broadcast data requirements. -This is obviously not an option for a lot of people, but it can be done. ;-)
    May 2024
    18
    Quote Originally Posted by Tre-Cool View Post
    Sure, but do a 2010 t43 accept a 2017+ os? If so then it's a non issue, but I don't think they are compatible
    Jan 2004
    280
    i can do it on our holden based cars just fine. i've done that os & 24256125 to 24267577 which is a 2016 os.
    May 2024
    18
    Ah perfect, ill try and see. Where can I find the OS for flashing with HP tuners? I have the mpvi3, but no idea where to get the newer os (and the right one) for it.
    Thanks alot
    May 2024
    18
    So seems like on "other tuning forum" they say thise are compatible, but I can't find anywhere to check year and download the OS for hp tuners
    24252573,24254909,24256025,24257135,24256065
    SoCal
    1,623
    Quote Originally Posted by tonn0297 View Post
    https://forum.hptuners.com/showthrea...l=1#post651541
    May 2024
    18
    Thanks, but don't show where to get the files 🙂
    SoCal
    1,623
    Thanks, but don't show where to get the files ��
    The repository was deleted due to....... .gov
    Anyways you might find a stock file in there, or you might not. It is likely I have a few on my server. I'll check tonight if I can remember.
    May 2024
    18
    All good, so what you are saying is I can take any 2017 os (.hpt) and flash into my 2010 TCM? Without bricking it?
    SoCal
    1,623
    Not saying that at all. I have no idea if that will work. That is a HUGE difference in years. I gave the link thinking your answer would be there.
    May 2024
    18
    seems like the 24276638 is the one i need, tho i can't find any way to get the OS alone, or to only download TCM os even tho HP tuners said in 2019 that it was a top priority... i do not wanna throw credits into a file i do not use the ECM
    SoCal
    1,623
    HP tuners will not do a complete re/program. That will have to be performed with SPS/Techline Connect. Again I will see if I have any of those OS's as an HP tuner file on my server when I get home tonight.
    May 2024
    18
    Apriciate it, do we know If a 2017 tcm fits in a 2010 case? Maybe the better way to go
    SoCal
    1,623
    If you have the two different VIN's then enter them into this separately and see if they are compatible as in the part numbers are the same.
    https://parts-catalog.acdelco.com/acesCat.php
    May 2024
    18
    Thank you! that is perfect, so the case and the valvebody have the excat same part numbers, and the TCM is a 24275873 on 2012-2019 and 24275874 on 2010-2011... so seems like a TCM is all that is needed. amazing news as a unknown state trans here is 2500usd and a reman is 7000...
    8,013
    HPT will, as long as you're talking only the TCM (not a Gen 4 ECM), either T42 or T43, without even costing any credits as long as the file you're writing to it is already licensed. Or a Gen 3 PCM, but that does cost credits to write an already-licensed file to a new/different serial# PCM.
    There are no segments in the TCM that aren't also in the .hpt file, unlike the ETC segments in the ECM.
    SoCal
    1,623
    Ya know I keep forgetting that it will do the TCM. Seem to get my brain wrapped around the ECM/PCM's.
