Page 5 of 5 FirstFirst 12345
Results 81 to 90 of 90
Thread: MpvI3 and Jtec+
  1. #81
    Jan 2022
    973
    yayyy
  2. #82
    Oct 2023
    15
    Just so everyone is clear - you can data log with the Stable build on a V3 so long as you re-poll for parameters after connecting to the ECU and using the configs found on post #35. I have not tried adding my wideband into the mix yet but am hopeful it logs fine. I?m assuming I will have to bounce back and forth between the stable build to datalog the car and then tune/flash the car with the beta build.
  3. #83
    827
    Quote Originally Posted by ViPER1313 View Post
    Dude you are a legend. The stable version + whatever firmware is on my V3 right now does find and log the channels.
    Not really. I just sent a request into support and after a few weeks they gave us a partial fix on accident.
    Hardly anything legendary, maybe worthy of a participation trophy.
  4. #84
    Oct 2023
    15
    Got a good data log. Just to confirm for everyone doing this, to do the flash, I need to use the beta builds correct? Stable still has flash issues with JTEC right ?
  5. #85
    Dec 2019
    27
    I have a 2020 Dodge Challenger and a 03 Dodge Ram with JTEC. My tuner said to always use beta on both vehicles.. stable isn't very much stable... LOL
  6. #86
    Oct 2023
    11
    97 Jeep Grand Cherokee 4.0l JTEC. VCM Scanner works for me after using layout on post 35 and repolling with stable version.
    How do you interpret the Spark Advance histogram? I understand the LTFT, mine is -15% so I would try to get that as close to 0 as possible by multiplying the tune fuel table by .90. But if you have a value of 17 in your spark advance, how do you interpret that to change your spark table?
  7. #87
    Jun 2022
    Canada
    00 Dakota R/T, 5.9L/46RE, JTEC+
    MPVI3 and the latest BETA works for writing to my PCM. Used Stable for reading the tune and datalogging no problem. Read the stock tune and all 3 Superchips tunes successfully, then flashed the superchips tune back with the MPVI3.
  8. #88
    Does the Superchip tunes change any of the transmission programing?
  9. #89
    Quote Originally Posted by scottie1134 View Post
    I have the MPVI2 and I can't write my 2004 Jeep wrangler. It appears that the cherokee people are having a similar issue.
    Well, after about a year of not really caring all that much, I finally flashed my jeep with the new MPVI3. It works. Turns out, for me, the MPVI2 was the problem the whole time. Fortunately it's only 1 credit to flash these older modules, so I just assumed I was out $50 or something. And a little bit of frustration. The jeep tuning is absolutely awful. I ended up picking up about 40 ft lbs down low and about 30 hp up top. It's whole different jeep now. Throttle response is actually a thing now. I wish I could do some trans tuning, but the scanner doesn't show output shaft speed. So I don't know if it's worth it to find another logging program to read trans output shaft speed in attempts to make changes there. But I'm pretty stoked about finally being able to enjoy my header and intaker. And no more CEL... so far
  10. #90
    Nov 2023
    This is kind of off topic, but what header are you using? Also have an 04'. Been looking at a long tube conversion.
