Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
Thread: Gen4 ls3 swap falls on its face while accelerating
    5BA8
    3,549
    Do you have a fuel pressure gauge on the vehicle? Have you tried starting it using spray? Starter fluid, carb cleaner, flammable brake cleaner, etc.? That would be first thing to try.
    Crazy as it sounds need to do whatever to make it start then see what your trims say it needs to run.
    email=[email protected]
    May 2024
    12
    Pulled the injectors but part number is scratched on all of them can't get a full number. It does have a 60 etched into the connector. can anyone help me identify the injectors and how to put them into the tune? pictures attached.
    I can get all but one digit of the part number if I'm looking at the right number 02801581*1 looks like it could be either 8,9,0
    2,959
    FIC did that. Among others.. It comes after they refit/redrill/reoriface whatever to a stock injector.
    But both of us have asked you to verify fuel pressure under heavy load and I haven't seen a response. There is a reason why two tuners are asking if you have done that. It might save us all a lot of time.
    Tuner at PCMofnc.com
    May 2024
    12
    Was the video of the fuel pressure gauge not showing up? Or do I need to make another one?
    2,959
    that doesn't look great to be honest. I'd continue to watch it... especially under a heavier load.
    It sounds like you got a miss other than that.. have you done the simple things? Wires/ plugs.. if you do a log with a wide open throttle pull I could narrow down which side it might be on.
  6. #26
    5BA8
    3,549
    Take a picture of the tip of the injector. I bet you'll be looking at the pintle.
    Sounds like it has big injectors along with the LSA map sensor. Might want to get a set of stockers. No telling what those are.
  7. #27
    May 2024
    12
    It has 4 holes like this. Yeah I think I'll look into stock injectors just so I have data on them. Also going to do a compression test on the engine. No idea how much boost previous owner was running.
