Results 1 to 2 of 2
Thread: Can't Write To Vehicle But Vehicle Is Licensed
    Mar 2024
    New Hampshire
    7
    When I try to write a new file to my ECU it says at the bottom unlicensed vehicle. to I recently had someone look at my tune file then email it back to me. It would only write if I chose "Write Entire". That tune wouldn't start the car. So I took another file I had and tried to write it. First time one file said "Failed" and wouldn't write because I have two ECUs and this file came from the wrong ECU. Finally I took the file I sent to this person and saved it as another file but when I went to write it at the bottom it says Unlicensed Vehicle even though it has the same VIN.
    Did I mess something up by writing the tune in "write entire" mode?
    Aug 2021
    Indianapolis Area
    456
    Do you still have this problem?
    If yes, share both tunes.
    DodgeBoy.
    YouTube: https://www.youtube.com/@dodgeboy2785
