Results 1 to 3 of 3
Thread: EOIT tuning
    May 2023
    14
    EOIT tuning
    Hello all, looking for some advice on EOIT tuning. Looking for a few rules of thumb i guess. Larger cam i want the SOIT to start later correct? and should i then have the boundary moved as well? my boundary is 520 across the board.
    as_found_may_20_24.hpt
    Cam specs
    intake [email protected] 268
    exh dur @ .006 274
    .553 lift intake
    .553 lift exhaust
    LSA 110
    LS4 turbo in a 1986 fiero...
    Thanks guys
    Sep 2023
    Bay Area, CA
    44
    keep it as found
    Aug 2021
    564
    Quote Originally Posted by tk1976 View Post
    Cam specs
    exh dur @ .006 274
    .553 lift intake
    .553 lift exhaust
    LSA 110
    Thanks guys
    Can you post a log as well?
    What injectors are you running? What heads?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
