Results 1 to 3 of 3
Thread: Bank 2 O2 reading 3% richer only at idle
    Nov 2021
    35
    I have a 5.3 bored to 5.7 stage 2 tsp cam, 799 heads. The Bank 2 O2 is reading 3% richer only at idle. I changed the intake gaskets and I'm trying to determine if this is a weak 02 issue or something wrong with the heads. Maybe an exhaust leak? The intake is a TBSS. I've sprayed carb cleaner all over to test for vacuum leaks.
    24-05-20 21-22-23.hpl
    tune 146 after intake gaskets replacement VE correction.hpt
    Daily driven
    Chevy Tahoe 5.3 bored to 5.7 3.898, flat top pistons
    TSP 212/212 112 LSA CAM, beehive springs, 799 heads
    TBSS intake and throttle body
    4l60e with shift kit and 2800 FTI stall, corvette servo
    13,610
    Honestly just forget about it and carry on, it's not even worth your time to worry about that.
    I don't even care if I'm 5% off at an idle.
    2,959
    Quote Originally Posted by Nestorxg View Post
    This isn't a perfect world. I just looked at your log and I do not see anything wrong with that at all.
    Tuner at PCMofnc.com
