Results 1 to 11 of 11
Thread: Idle and initial drive tune support needed
    Apr 2020
    6
    Hi all,
    Looking for a bit of help in building out a tune to get the car idling and in a driveable state after upgrades.
    2000 LS1 out of a Camaro swapped into a 2002 Honda S2000. I had the motor, 100% stock with a LS6 MAF, mated to a slightly built T56. It was in the car for about a year, working out kinks with the swap before pulling it.
    Motor is ready to go back in after upgrades... I made a lot of changes and don't really know what to do to get it back running...
    Motor configuration I am looking to tune, coming from a 100% stock + LS6 MAF set-up. I highlighted what I think is most pertinent to the tune.
    • Trickflow 225 Heads, 63CC chamber, and powdered metal guides
      Brian Tooley Racing LS9 multilayer gasket, 7 layer
      Stock rockers with Smith Brothers Bronze bearing trunion kit
      Brian Tooley Racing 0.630" lift dual spring with steel retainers
      LS7 Lifter, Trays, running 7.475" 5/16 pushrods
      Brian Tooley Racing Stage 3 NA LS cam, Specs: 231/244 .630"/.615" 112.5+2.5, INTAKE LOBE LIFT @ TDC: 0.05810
      IWIS Single row chain
      Meling High Flow/Pressure Oil Pump
      FAST 102 Intake
      FAST 102 Big Mouth TB
      FAST 36lb/hr (378cc) Injectors
      GM LS2 Fuel Rail
      GM LS6 MAF out of a 2003 Z06
      Currently as NGK TR5 plugs
    I attached the last tune that was in the car. Speedo and related stuff is a bit of a mess to get the LS PCM to work with the stock S2000 dash. Car ran decent on the tune, no issues with AFR at WOT.
    I do have an wideband AFR and Oil Pressure gauge in the car.
    Any guidance on what to change in the tune to get it to idle is appreciated! I do plan on having it given a real good tuning with a local shop known for their work on LS motors later in the summer.
    05142021_ speedoadjust.hpt
    Arizona
    572
    13,630
    FAST doesn't have proper data for HP Tuners, those are kinda worthless.
    Dec 2019
    3
    I feel like this statement needs clarification. I'm using the FAST 303608, after a set of re-man GTP injectors stuck open on me. If the thread below is wrong, would be good to know.
    https://forum.hptuners.com/showthrea...b-hr-injectors
    Quote Originally Posted by SteelDr89 View Post
    People reply with what they know. Fast is well known for not providing gm data, and most people have no idea that some have been cross-referenced to known data. If you look at the dates, that poster joined the forum 2 years after that thread was started. He probably has never seen it.
    Mar 2022
    Indiana
    3,146
    The injector data is certainly not correct. Look at IFR. Here's the GTP data:
    https://forum.hptuners.com/showthrea...l=1#post745105
    It'd be ideal to get a different set of injectors. Actual GM ones with 100% factory data:
    https://forum.hptuners.com/showthrea...l=1#post766924
    Convert the tune to the 1bar SD OS. Tune VE and forget about the MAF.
    5BA8
    3,648
    That cam will definitely run better in SD. 100%
    email=[email protected]
    3,027
    Those injectors are pretty easy to work with IMHO. I wouldn't change them. We use them in house for smaller builds in house although you'd have a hard time maxing them out NA.
    Post a log. A lot of initial start up stuff has issues to diagnose. Sensors not reading as they should. etc.
    I agree this would be best in speed density.
    Tuner at PCMofnc.com
    Apr 2020
    6
    Thanks for the initial replies. Got some reading to do!
    I'll look into SD tuning as well.
    Motor goes back in car this weekend but probably won't being a position to start and log for another couple of weeks.
    Apr 2020
    6
    Thanks Sirius for the info. I was able to find all the places to input the 36lb GTP injectors you linked to but the last one. "Fuel to Wall" transient. I found something similar "Fuel to Wall Impact Factor" that has very similar labels but not exact. The Y axis goes in steps of 20 not 10 like in the excel sheet, and the X axis labels are slightly different. Is this the right spot to input these values or am I missing the spot to enter them?
    Apr 2020
    6
    Edcmat, any threads that are worth reading on how to get started with an SD tune. I did a search and nothing popped out as being helpful. I did find a thread on LSTech outlining how to get the ECU into SD mode and initial start-up for tuning, but it lacked info for me to fully grasp what I was changing.
