Page 2 of 2 FirstFirst 12
Results 21 to 26 of 26
Thread: car dies when coming to an idle from acceleration. ls3 with chopacobra
    Mar 2024
    28
    If you looked at my updated tuning file, you would see that I knocked that all the way down
    Mar 2024
    28
    I drove it.hpl
    #10 VVE-MAF test ss. braf idle test.hpt
    i actually got to drive it today got my shifter swapped out and it died doing a 3 point turn when i went to turn it around in the lot i feel like its getting closer. do you have a reference to vve table tuning on these gen 4 ls engines im not familiar with ls or ve tuning its all new to me
    Aug 2021
    910
    Quote Originally Posted by moesmopar View Post
    I drove it.hpl
    Right now your BRAF table needs work. Once you are able to drive it without it stalling, you can tune the MAF and VVE. I just added a quick 2% to the whole BRAF table to see if this helps with stalling. Add Proportional & Integral Idle Airflow to your channels in the scanner.
    #10 VVE-MAF test ss. braf idle test (1.2.hpt
    Mar 2024
    28
    uploading it now. i will update after i try it out and make a few changes myself
    Mar 2024
    28
    Well bad news never got to try the tune, the interior guy spray painted into the obd port and I didn?t realize and caused bad connection during the write and bricked the pcm -_- looks like the car is gonna miss Comicpalooza :sad:
  6. #26
    5BA8
    3,640
    I'd clean the connector pins and try again. I've never seen a GEN4 PCM "brick" during a normal write process, especially a write calibration. HPtuners even has a recovery mode in the case that something does go wonky during the write. That just doesn't sound right. You may be experiencing a condition you're unfamiliar with trying to diagnose and just interpreting it as a "bricked" PCM.
    email=[email protected]
