The black box computers use a % value for base running airflow, "Idle % airflow" Is there a way to log this in the scanner? All of the idle air flow tuning info I have seen doesn't mention anything about the % values.
Thank you, all those are about MAF and VE tuning and still don't mention anything about how to monitor "idle % airflow" for idle tuning. I've gone thru the MAF and VE tuning and it idles ok I just wanted to cover all bases. Its the easiest tuning process on newer computers that use a measured volume, the % thing has me confused a little.
