Results 1 to 9 of 9
Thread: cold start help
    Apr 2023
    missouri
    11
    cold start help
    have a 07 non dod 6.2 with headeras and btr stage 2 cam. warmed up the vehicle will pop off quick after stitting all night takes a few tries. any help or input is apprectiated
    5BA8
    3,640
    Have you checked fuel pressure? Could be bleeding off overnight. Not everything is fixable with the laptop. Need to cover the basics first.
    email=[email protected]
    3,015
    I'd check fuel pressure.. Put the gauge on before you do anything else one morning.
    Tuner at PCMofnc.com
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    266
    If it is bleeding off could be an injector leaking. See any smoke on start up?
    2013 CTS-V Coupe M6 - 1 7/8" Headers, 3" x-pipe, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSXtuning flex fuel kit, DMS under hood tank, upgraded pump, 3/4" lines, griptec 2.4" pulley, solid isolator, 100mm idler, reinforced brick, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq
    Apr 2023
    missouri
    11
    no smoke does seem super rich when it pops off after a few
    Jul 2020
    VIC Australia
    1,223
    Try halving the entire start air flow table and set cranking ve to 100
    Apr 2023
    missouri
    11
    checked fuel pressure after sitting over 12 hours. 48 primed cranking 58. got it to start again and no issues when ran for for at least a min. does have new plugs and wires
    3,015
    Did it have fuel pressure when it had the hard start?
    If so.. I'd multply the cranking airflow table by 15-20% +
    Aug 2021
    581
    Quote Originally Posted by Cjh1284 View Post
    Please try this and report back.
    Flash it, start the truck then, shut it off and let is sit overnight. Try the cold start in the AM and report back.
    5-21-24-7kyle-cringer.hpt
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
