Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
Thread: 2011 CTS V - Help with this VVE ridge at 2600 RPM
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    328
    Quote Originally Posted by sgod1100 View Post
    This may have been done before, but has anyone tried a "write entire" vs. "write calibration"? I doubt this will do anything but.....
    I've done a write entire when I did an OS patch. I want to try tightening up the FP pressures and injection timing to see if it helps.
    2013 CTS-V Coupe M6 - 2" Headers, 3" x-mid pipes, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSX flex fuel kit, DMS 2g under hood tank, ZZP pump, reinforced brick, 3/4" lines, AFCO HX, Griptec 2.4" pulley, solid isolator, 100mm idler, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq on e85
    Feb 2018
    919
    Quote Originally Posted by JayRolla View Post
    Sounds good..let us know if you make any improvements
    Aug 2021
    760
    I assume the HPT 2 bar custom OS has been tried as well?
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
    Feb 2018
    919
    Mine doesn't have that option
    Mar 2021
    328
    Really, I think my 2013 had the option. I have not tried it yet.
  6. #26
    Aug 2021
    760
    Yeah it looks like you can apply it on a 2013 OS, but it is not available for a 2014 OS.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
  7. #27
    Aug 2021
    760
    BTW I have a few new ideas and theories about what is going on. If anyone would like to do some testing I would like to try to help. PM me. I will need the current tune and a decent log.
    My Tuning Software:
    MAF Assistant
    EOIT Assistant
  8. #28
    Feb 2018
    919
    Yeah, mine is a 2014 so that makes sense
