Thread: Cadillac CTS 3.6 2011 problem with long term fuel
    May 2024
    Good day, friends.
    This problem occurred long term fuel bank 2 +10%
    long term fuel bank 1 +6%
    what could be the problem?
    log at idle speed.
    The engine also shakes at idle speed.
    Tuner CYN_CRVR's Avatar
    Jul 2023
    Los Angeles
    68
    You're also getting knock retard when you blip the throttle.
    Did these issues begin suddenly?
    Is your car stock or modified?
    Are there any check engine lights?
    May 2024
    I didn't notice the problem before. the injectors have failed.
    What was accomplished.
    Replacing injectors.
    Replacing oxygen sensor 1 bank2
    Cleaning the throttle valve
    MAF cleaning
    I removed the second oxygen sensors
    Replacing spark plugs
    Replacing coils
    Compression measurement in cylinders is normal (12) slight difference +-0.3
    There is traction in the engine, the gas pedal reacts quickly, there are no errors from oil change to change.
    YES STOCK
    no engine errors
    Yesterday I increased the parameter in the Engin-fuel firmware - flow rate - injector const by 15% and set the value = 0.04402.
    and wrote a new log
    Jan 2023
    TX
    5
    Can I tune my 2015 SRX with a better fuel efficiency and remove stabilitrack? this car swallows gas stations!!
