I see lots of people adding 87mm throttle bodies from the new 2023 super duties, but how and where do you find the data for this throttle body at?
I think the Godzilla control pack comes with an 87mm TB which is also the same size as the 23 throttle body. Can you just steal whatever you need out of the control pack file?
Godzilla control pack comes with an 87mm GT350 TB afaik, should be able to pull the data from a stock GT350 tune.
I believe its the Mach 1/bullitt throttle body, not sure what the difference is between it and the GT350.
