Page 2 of 2 FirstFirst 12
Results 21 to 29 of 29
Thread: Can a new 6L80 TECM/TCM be configured with HP tuners?
    8,100
    Do not read anything from the vehicle after the new trans is in. You don't want anything that's already in the new TCM. You want to put your old file (just the TCM) into the new one. When you go to write it, pick 'do not write' for ECM, and 'write entire' for TCM.
    8,100
    Quote Originally Posted by 1Topgun View Post
    I have a similar question related to installing a new CPP Supermatic 6L80E trans (part #19432680) in my 2013 Suburban 1500. The install sheet with the trans indicates that the interface cable (included with the trans) contains a one-time license to connect the TCM for initial use with a file on a USB drive. It also says that the trans will not function in a production vehicle. BUT, if I read my old TCM file and save it to my laptop, will I be able to write that file to the Supermatic TCM instead of using the interface cable that is included with the new trans?
    Has anybody here installed a Chevrolet Performance Parts Supermatic 6L80E transmission in a production vehicle?
    Thanks in advance!
    Why do any of that? Why try convert a trans specifically made (and priced, I'm assuming) to be a stand-alone thing for high-dollar hot rods into a non-stand-alone? Sell it to some rich guy and buy a normal reman transmission and use the leftover money for a vacation or something.
    Apr 2024
    7
    So got everything installed, connected the dongle, opened my read out from yesterday morning, hit write, set ECM to "Do Not Write", set TCM to "Write Entire" and this happened:
    Completed successfully. Never asked for, or mentioned credits - just wrote the file. Took 5-6 minutes which seems correct for a full write. I assume I am good? Just a little concerned that it didn't ask for me to buy a credit...
    8,100
    Swapping out only the TCM and writing a file you've already licensed doesn't need more credits. Can't do that with the ECM though, that breaks the license.
    Apparently, according to what HPT has said here, it would be possible to flash an unlimited number of T42s or T43s with your custom tunes, as long as you had a license for the file you were writing. I'm not endorsing that, but they could have made it not work that way if they'd wanted to, so...
    Apr 2024
    7
    Interesting.
    So then I guess I am good. The trans did have a bright orange tag that said it had a dyno test cal in it which IIRC we discussed before had the necessary bootloader to get an HPTuner write to work so I am not too concerned with how it all went. I was surrised about the credit thing since everyone I've talked to thinks the ECU serial number is tied to the credit and since I changed to a different ECU with a different serial we all assumed it would need a credit.
    No worries though and I can't thank you enough for your help!
  6. #26
    8,100
    You changed the TCM (transmission) which does not have its serial number tied to the license. If you change the ECM (for the engine) it will prompt you for credits. Your license is a combo of the ECM serial number and your tune file.
  7. #27
    Oct 2023
    So Chad how did it go with trans tune ,
    I need to know I?m on that door step
  8. #28
    May 2024
    Memphis
    I have a 2021 with a T43 TCM, however I can not get HPT to read the TCM in order to turn lock-up off in 1st-4th gear. Any help would be greatly appreciated.
  9. #29
    8,100
    Quote Originally Posted by reece0325 View Post
    What does that have to do with programming a new TCM, which is the topic of the thread you jumped onto the end of here?
