Results 1 to 8 of 8
Thread: No communication with ECU
    Jun 2024
    5
    After having HP tuners Vcm scanner connected to the computer I noticed I lost comms with the ECU. Now all the warning lights, including gas light etc flash like it?s stuck trying to communicate with the VCM. Have tried everything to reset but still no success in connecting to my ECU. So the car will not even try to turn over. Any help would be greatly appreciated.
    Jun 2022
    7
    Sounds like the ECU is bricked. If you get ahold of Dmitry (ecuresearch.ru) he can help you recover it via bench flash with a tactrix cable.
    Aug 2021
    Indianapolis Area
    454
    Which vehicle?
    Which MY (model year)?
    Did you try flashing/writing ECU/PCM/TCM?
    Do you have MPVI with credits?
    DodgeBoy.
    https://www.youtube.com/@dodgeboy2785
    Jun 2024
    5
    Sweet I will try that. Looks like it?s a download? I have everything for tactrix and was running that before went to HP. Never had these problems with tactrix. Thank you!!
    Jun 2024
    5
    2019 Sti base. Have credits. I was connected to the VCM scanner when it happened.
    Aug 2021
    Indianapolis Area
    454
    Quote Originally Posted by Taintedsubiez View Post
    While connected, were you only logging or performing any procedure?
    Could you share the base tune (in case you have)?
    DodgeBoy.
    Jun 2024
    5
    I was only scanning no flashing or anything.
    Quick update. I got the ECU figured out and it?s fine. Once it?s in the car I can not connect to it. I can only connect on bench setup.
    Jun 2024
    5
    I would post a video what my dash does but can send it on this forum.
