Results 1 to 6 of 6
Thread: just changed to 4.10 gears in my 2006 5.3 5 speed tranny and need to calibrate speedo
    Feb 2024
    ok i am stumped on how to make the speedo work correctly on my 06 silverado 5 speed. i just switched to 4.10 gears and it will not correct it the right way in auto scaling ?
    Feb 2024
    i have a 29.2 tire with 4.10 gears now with the stock 5 speed trans
    Arizona
    1,271
    Quote Originally Posted by ahurl90 View Post
    Have you used the bluecat trans tool to reset all the shift points?
    Dec 2019
    MS
    1,238
    Quote Originally Posted by bk2life View Post
    Silly... He has a 5 speed manual transmission...
    Dec 2019
    MS
    1,238
    Speedo > Calibration
    ECM 5002 (Trans Revolutions/Mile) - 2831.825
    ECM 9000 (VSS Pulses Per Mile) - 113273
    ECM 9050 (Final Drive Ratio) - 4.10
    Oct 2022
    i just came across this old thread cause i am having the same issue the only difference is i have a 28.7 tire and the same 4.10 gears. can someone help with the formula to dial in my speedometer? i already tried the gear/tire wizard
