Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 67
Thread: Can someone evaluate a remote tune for me?
    Banned
    Mar 2022
    Indiana
    4,289
    I think what smoked the trans is the shift times and rpm. Inertia squares with rpm. The trans was absorbing all that to get rpm down after a shift. Have to give time for not only the trans itself to make the shift but for torque to truncate too. Then again, it has to be setup for torque to be truncated. Pretty much power shifting at 7 grand and wondering why the clutches can't take it.
    On the other hand the driver should've noticed this early and realized he wasn't slipping the tires.
    5BA8
    5,567
    I see your point but like I said I've seen worse NOT smoke a trans like that.
    NM.....
    email=[email protected]
    5BA8
    5,567
    Both those "pulls" it looks like it's in TUTD and the driver never shifted. Don't know if that's just the PCM not commanding the shift or if the driver didn't hit the TU button.
    Definitely the RPM and the lack of upshifting is part of what killed it. These things need the MPH and RPM shift points LOWERED to get them to shift on time. That engine is spinning too high for a stock bottom end. Surprised the trans is the only thing smoked.
    Also, could be a low fluid issue. They're difficult to get full. Most people don't.
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    359
    Im a manual guy so dont know for sure, dont people also recommend over filling 1 qt?
    2013 CTS-V Coupe M6 - 2" Headers, 3" x-mid pipes, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSX flex fuel kit, DMS 2g under hood tank, ZZP pump, reinforced brick, 3/4" lines, AFCO HX, Griptec 2.4" pulley, solid isolator, 100mm idler, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq on e85
    5BA8
    5,567
    Quote Originally Posted by JayRolla View Post
    Yessir. I typically tell people check the fluid level according to spec at least twice. If you're unsure, check it again. When you're confident it's full, add 1 quart.
    If it's a new build it needs to be checked, topped off, ran through all of the gears and lockup, and then checked again which requires a cool down.
  6. #26
    Arizona
    365
    Dont you just love it when you get a car that just got a new stall to tune? I'd have to say that 80% of the time, the trans is low on fluid.
    Like you said, fill, check, fill again, check again, then maybe wait a day and check again! lol!
    2009.5 PBM G8 GXP M6 W/Roof-Self tune, OBX LTs, Kooks axleback, LSA blower, cam,
    Monster LT1-SC clutch, flex fuel, 12 psi [email protected] 1,800 D.A
    2007 TBSS-Self tune, bolt ons [email protected], 1,900 D.A
    1991 GMC Syclone- Self tune/catback 12.8@104, 4,200ft D.A
  7. #27
    5BA8
    5,567
    Quote Originally Posted by STAGEUP View Post
    Exactly. Just when you think it's full, wait 24 hrs. and check it again. You'll be surprised.
  8. #28
    Mar 2021
    359
    Thats that automatic life. I wouldn't know. I like to be slow. HAHA. 25 years of performance 4 bangers and v8's and yet to own an auto.
  9. #29
    Arizona
    365
    I'm with you!M6 life for me. See sig.
  10. #30
    5BA8
    5,567
    Banging gears is fun but I'm an auto guy. Primarily it's about drag racing for me. And I love a really well tuned auto going through the gears without hitting the limiter, just gettin werk dun!
  11. #31
    North Carolina
    4,929
    Absolutely. I think they work out air pockets or something. A lot of transmissions will start to miss shifts just a half a quart down.
  12. #32
    Jun 2024
    21
    There are roughly 200 miles on it. Maybe 6 wide open throttle pulls.
  13. #33
    Jun 2024
    21
    I prefilled the torque converter.
    Pumped as much fluid as I could into the fill port
    Started the car and let it idle to temperature (88)
    Ran it through R, D, N, R, P at 3 to 5 seconds each
    Opened the full plug
    Pumped roughly 12 quarts into it until it dribbled fluid
    Pumped 2 more quarts into it
    https://static.summitracing.com/glob...-8100a-jmb.pdf
  14. #34
    5BA8
    5,567
    Would have been nice to see some early data logs before it was already smoked.
    I suggest on the next one you put pretty much everything back to stock on the trans side and see how it feels on a bone stock calibration.
    Lower your rev limiter to something reasonable. Lower your WOT shift RPMs MUCH lower than your rev limiter. I'd start around 6500 on your rev limiter and 5000 on your shift RPM. See how it shifts on its own, not in TUTD.
  15. #35
    Jun 2024
    21
    https://drive.google.com/drive/folde...Mc?usp=sharing
    uploaded a bunch here for your perusal
  16. #36
    5BA8
    5,567
    Yeah I'd say that's a bunch LOL
    Can you elaborate on the time frame? I see they go from April to June. Is this from BOTH failed trans or just the built one? Just looking for some background on them before I spend a bunch of time looking through them.
    Correct me if I'm wrong but you're on trans number 3? OE one breaks a shaft, that's one. You had it (2) built and smoked it. Builder goes back through it again (3), and you smoked it again?
  17. #37
    5BA8
    5,567
    Are any of those in the folder WOT logs? I looked through 3 or 4 and they were all part throttle easy driving logs. At quick glance they looked fine. Did not go into great detail as I was mostly looking for WOT pulls.
  18. #38
    Jun 2024
    21
    3rd.hplhit.hpl1234.hpl
    1234 has a WOT at the end
    3rd is a third gear pull that i shifted into 4th manually (if i remember correctly. it was about a month ago)
    hit was a "wot hit" requested by the tuner. 3rd gear pull.
    i've been doing pulls on a back road, but i'm limited by the roads i can do it on.
  19. #39
    Jul 2020
    VIC Australia
    1,515
    shit, 1234.hpl shows why your trans got smoked. See the rpm rate of change lay over when the oncoming clutch was pre-filled. That's your 2 clutch packs turning into a thermal source to heat water into steam to drive a turbine. Attached is a solid 6L90 tune that you can use in your new trans.
  20. #40
    Jun 2024
    21
    I really appreciate it but I'm working with another remote tuner.
