Backstory, wrapping up a very long saga of an LS Swap. ECU was "Tuned" by a very prominent company and person. I wont put them on blast because this project has dragged out years and life goes on. Engine was running terribly and smoking like a train. I thought the amazon special 8.1 injectors were at fault, bought new "42lb" ones from FIC (connection), along with the fuel pressure regulator and it was still smoking. At that point I said F' it and bought HPtuners today and within about 5 minutes realized suspicions were correct and the stock injectors were in the tune, so it was dumping double or more the needed fuel. Oil was full of gas, spark plugs were black, etc. On the upside my fears that the smoke was rings or valve seals was alleviated. "tune" wise it looks bone stock from what I can tell. VATS and standalone modification were done by LT1Swap Brent prior to a quick refresh and cam swap.
Specs:
LQ4, Stage 3 truck cam, headers, dual 2.5 exhaust in a GM A-Body. 42lb FIC injectors, actually flow 50ish at 58lbs, truck rails and return style regulator. 700r4 transmission, so no tcu components. I've also attached that spreadsheet I received.
Where I am now: I changed the injector data with the data supplied by FIC. No smoke and it idles better but is not steady and has popping from the exhaust. What I've attached here are the tune as received and the iterations thus far along with a long of the latest idle. There's something up with B2S1 o2, and I replaced it but it remains stuck at 1v. I'll be troubleshooting that for a possible harness issue next weekend. If I understand things correctly though in open loop which is it currently is, it is not using the o2 sensors so the bad idle and occasional pop would be tied to the tune, either not enough timing resulting in fuel burning in the exhaust, or it is lean popping.
I really don't plan to get to heavy in this, just need it idle okay and drive like a useable car for right now. I'm usually pretty good with software and learning things but definitely in over my head for the moment. Within a year I'll either be doing heads/cam or a supercharger and at that point get it over to a shop on a dyno and try to push all the power out it can.
I've been saving as I go with rev numbers to avoid f'ing anything up irreversibly. Attachments have revision numbers. I'm pretty busy during the week so it'll be next weekend likely before I can get anymore log data up but for anyone willing to help I will certainly do my best to get any log info I can when I can.
As-Received is as received
Rev1 I changed the injector flow rates
Rev2 I changed the volts and offsets per the spreadsheet
Rev3 I went up 10% on the idle airflow. It seems to be lean and a larger cam, so I figured upping the idle airflow would get it richer.
Log is after Rev3 was written to the ecu.
