Results 1 to 8 of 8
Thread: Still lean problems
    Jun 2023
    21
    Still lean problems
    2009 Chevy Express Cutaway 6.0. Keep getting permanent lean codes on 02 sensors both banks.
    We ran the smoke test thru intake found no leaks. Changed MAF, changed all 4 o2 sensors, still get the same codes.
    I got the tune from the repository here, checked files, nothing different. I was hoping someone in Philly or Ohio did something to it. As I was comparing, I see a table that says closed loop vs 02 that is appears to richen the mixture under certain conditions. The entire table is at 0.0.
    Down to the last week to go thru emissions. I got Bosch o2 sensors, but the wagners are called OEM design, so I am thinking maybe the way the exhaust is monitored might be different.
    Checking underneath with a temp gun thinking we have a blockage in the cats, all temps were noticeably cool. I am talking 320 or so at the exhaust manifold, 190's pre cat, and 130's post cat. The other codes that show up are heater circuit resistance and power to heater circuit. What is the purpose when its 100 degrees here in Chicago, why do the heaters need to work and stay on.
    Just trying to figure out the reasoning. I was thinking pull the fuses of the heater circuits, but that will most likely throw a code anyway. Here in Illinois, check engine light on, they wont even plug it in, even if its a code that has nothing to do with the emissions systems.
    So be parts changers and get no answers, you look to what might have been done, like gutting cats maybe? Either way, I see a table that is not supposed to do anything apparently, that can richen the mixture and might actually fix the issue, so I thought someone could help.
    So far we have just read this vehicle, so I have not played with anything I should not have yet.
    5BA8
    5,570
    Hold on!
    This is a job for........
    email=[email protected]
    Feb 2018
    951
    Hold on!
    YESSSSSSSSSSSSSSSSSSSSSSSS....lmao
    North Carolina
    4,932
    Is this a completely stock van or is it a swap or something?
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,172
    Quote Originally Posted by anotheridiot View Post
    Are the O2 sensors reporting any voltage? Like 100mv or 0v?
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
    Jun 2023
    21
    They start to as new, but then flat line. The front ones keep reading and show a graph, but the second two both flatline.
    I know you spit fuel on these things and fry them, but there is nothing coming up as rich.
    Jun 2023
    21
    stock van that we have not messed with. The MAF sensor had a broken pin, that is reading like .86 then .78 or so as it warms up and the rpm's drop.
    Aug 2021
    1,172
    O2 sensors, as the name states, sense the presence of oxygen, not fuel. So if are spraying raw fuel on them (such as a misfire) it will read lean.
    You really need to post the tune and log file.
    MAF Assistant
    EOIT Assistant
