Results 1 to 14 of 14
Thread: Issues logging with wideband on EGR circuit
    Jun 2024
    15
    I have an AEM gauge 30-0300 I have connected the white wire to the pin 55 and the brown to ground when I look at the scanner shows 0 volts on the EGR and 7.31 on the chart I checked the wire on the computer and it showing 4.5 volts and checked the white wire on the gauge shows 4.5 volts. Gauge shows 14.5 at idle. Is the white wire from the gauge supposed to show different voltage? or is it something I am missing on the tune. Thanks in advance for the help.
    Oct 2004
    688
    A zero volt reading on the scanner means EGR is not enabled in your tune. If it was enabled you would show phantom millivolt readings even with nothing attached to the pin. The current version of HPT does not allow you to change this, so you either have to use an earlier version of the software or some other tuning software to enable it. With any luck someone here will modify it for you.
    Jun 2024
    15
    Quote Originally Posted by gametech View Post
    Yeah hopefully someone can help..
    Oct 2004
    688
    Try this, but no guarantees. I don't have an older version of HPT, so I have to use a very roundabout way of changing that flag to enable.PRVN 2000 SIerra Manual edit 4.3 1 egr on.bin Shit, I attached the .bin version. Let me try again.
    Jun 2024
    15
    That fixed it thanks gametech. Appreciate the help. Can I ask what was changed??
    Oct 2004
    688
    Quote Originally Posted by IsidroL View Post
    There is an enable/disable setting for EGR that hptuners no longer gives access to. You have to be cautious doing this, as there is also a table that modifies spark based on EGR. I made sure that table was zeroed out in your file.
    Dec 2024
    27
    Hey guys I have the same issue, voltage reading 0 and 7.3 or whatever.
    Is this still a thing that you cant enable in HPT? I wired this wideband ion and set it all up for volts, but now its not reading the source as the OP (6 months later srry)
    I dont wanna have to open a new thread on this if someone can shed light.
    Running an 02 camaro base tune on my stock ls6 (05 cstv) on a truck PCM and trying to dial in my sensors for a better startup tune and light street tune. Need to get this wideband datalogging....
    Advanced Tuner Matt Vardaman's Avatar
    Mar 2021
    208
    Quote Originally Posted by 570_sx View Post
    post your tune file and I'll turn on egr for you. I have two versions of hpt. I usually run the older one.
    2001 Silverado 5.3 - 209/217 cam, GT45 Turbo, 4L80e swapped with Summit pro ls 2500rpm converter, on Ethanol with content sensor.
    1999 Silverado 6.0/4L80E Summit Stage one camshaft, 317 heads (replaced cast iron)
    Mar 2024
    3
    Ive been trying to get my aem 30-0300 gauge to work through egr and finally this thread makes sense as to why I cant...2002 lm7 white wire to pin 55 ...egr always reads zero no matter what, no option to enable or disable egr like ive seen in some older you tube videos.
    Here is my tune, hopefully this thread is still current enough to post to for a response...
    Arizona
    1,284
    Quote Originally Posted by rvfixerguy View Post
    there is an entire thread dedicated to turning on EGR...
    find it, not this thread.
    Dec 2019
    MS
    1,252
    Try this
    Mar 2024
    3
    Quote Originally Posted by bk2life View Post
    Ya sorry I found it after I had already posted here....this was the first thread that popped up in my search
    Mar 2024
    3
    Quote Originally Posted by RDF1 View Post
    Try this
    Thanks for your reply! I will try and continue in the other thread...
