Results 1 to 8 of 8
Thread: afr500v2 can
    Sep 2021
    Kentucky
    1,839
    afr500v2 can
    Just setup my v2 can for obd, waiting on the adapter to come in. Ballenger software is locked at 1hz for hptuners. Will i be able to request faster polling in the scanner? Id think 25-50 would be much better polling rate.
    Sep 2021
    Kentucky
    1,839
    Also, left my baud rate at 500kbps. Is that pretty standard or can i do better without stressing the wb or getting bad data?
    Sep 2021
    Kentucky
    1,839
    Ive got it up and running but havent had time to sit and play with the new wb. Ill see if i can learn more about it tomorrow and post back for the next guy. Just a bonus it will not poll the parameter if the obd2 passthrough is laying in the passenger side floor.
    EDIT: forgot to play with unit
    Loving the can unit for sure, not so sure about the bosch 4.9 i let calibrate 45-50 minutes. Seems more rich than normal compared to my dyno wb. Ill keep using the 4.9 on the 6 TN or chopacabra build i tune per week and eventually get a ntk and do some real cal work. Anybody questioning a can v3 unit definitely order the thing.
    Aug 2018
    7
    1hz is not used by the AFR500 in HPTuners mode as OBD2 is request/response, If you want a faster rate you can right click on the channel and change the `Polling Interval`. The 500k Baud rate is not changeable OBD2 communications breaks if you change it, it's a set OBD2 standard.
    Sep 2021
    Kentucky
    1,839
    Thanks for the response. I have been using this a lot but have not adjusted polling interval. Whatever default is seems to be working fine. I completely forgot to play with it as the response seems just fine.
    Sep 2021
    Kentucky
    1,839
    If they end up having good support for the bosch adv id like to upgrade to a v3.
    Banned
    Jan 2022
    fountain valley
    2,379
    i have both the 500v2 analog and the v3 CAN
    the v3 samples at 10 hz
    i do not know why it says 1 hz in their device manager
    you can put the settings wherever you like... it will not sample any quicker than once every 100 ms
    not sure where they are seeing the "4x faster" they are referring to in their description
    Sep 2021
    Kentucky
    1,839
    I ended up getting a v3 can but i havent even used it. Its setup and calibrated sitting in a drawer.
