Results 1 to 9 of 9
Thread: any advise on my tune
    Feb 2023
    42
    2015 silverado 5.3 dod delete cam is 220/220 .527 .527 lobe center 109 center line 105reee.hpl2014 chevy tun.hpt
    A datalog would help. But at a quick glance some things I noticed,
    Your spark tables need some work from 0 to .64. Top end of your spark tables look decent though. Your driver demand could use some smoothing out too.
    Is your transmission built? Looks like you have that thing set on kill mode.
    Feb 2023
    42
    No transmission is stock other than just shift kit in it
    Feb 2023
    42
    What recommendations for the transmission just want the truck to run good feels very slow when pulling out of a stop it used to spin the tires easily when engine was stock no it won?t at all
    North Carolina
    4,846
    That cam likely killed power up until mid 4k RPM.
    Do you have headers on it? That will help.
    Too big of a cam for a stock compression 5.3 without doing a converter. You trade off low-end torque above 210 on the intake lobe. Long tube headers as mentioned and bumping up compression will help off set this.
    Feb 2023
    42
    It has short headers cold air intake phaser lock out has a stock 6l90 converter
    405
    3,231
    Aren't those DI 5.3s already 11.5:1 compression?
    Quote Originally Posted by SILVERADO14 View Post
    Short headers are no better than stock.
