Thread: does anyone have access to an 8 speed automatic transmission TCM Wire Diagram?
    Feb 2024
    canada
    50
    I'm working on my bros car and it lost communication with the tcm, trying to figure out where the power to the tcm comes from, i've looked everywhere and cant fin a diagram. your help is appreciated!!!
    Banned
    Jan 2022
    fountain valley
    2,379
    what kind of car or truck is the transmission in?
    Feb 2024
    canada
    50
    2012 chrysler 300 awd! thanks for the reply bro.
    Advanced Tuner Spray-Cam Hell-Ram's Avatar
    Aug 2021
    Yorktown VA
    256
    should have a yellow/red wire coming from the TIPM. Its fuse 57 on my truck, not sure which on yours but should be labeled on the TIPM cover. Its a 20 Amp fuse. And then you will also have a Pink/White wire in the tcm plug for Ignition Run/Start Control which is coming from the BCM. Aside from those two wires, you should just have a ground wire (Black) and 2 canbus wires (Violet/White and Yellow), 2 data bus wires (White/Brown and White/Orange), and finally a transmission park signal wire. Mine is Yellow/Dark Blue and comes from my Radio Frequency Hub mounted on the rear cab wall right in the middle behind the console splitting the 2 rear seats. Those are the 8 wires you need to control the trans/tcm.
    "1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
    +6cc Mahle Dome Pistons w/ 13.1/1 Compression on E85
    Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.65" Valves
    Custom Cam 220/238 .611/.589 108.5 LSA 108.5 ICL, 105mm Hellcat TB
    Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
    Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
    Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
    Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
