Page 4 of 14 FirstFirst 12345678 ... LastLast
Results 61 to 80 of 279
Thread: getting knock under wot
  1. #61
    Banned
    Mar 2022
    Indiana
    4,289
    Yeah. And if I change OS's to one that supports flex then my VIN will be invalid for model year.
  2. #62
    Aug 2024
    Texas
    174
    yea I have a bung off the y pipe from the headers. Had hard time keeping the scanner going it kept stopping on me. However, I've been running around for several hours and no-knock retard. The only thing that I've notice that doesn't seem right is the lack of Torq down low doesn't spin the tires that well or at all sometimes.
  3. #63
    Banned
    Mar 2022
    Indiana
    4,289
    I still don't see the wideband in the log.
  4. #64
    Why does that matter? HPtuners problem?
  5. #65
    Banned
    Mar 2022
    Indiana
    4,289
    Because the ABS and SRS modules are VIN coded. NHTSA thing probably.
  6. #66
    I wonder why they won't let you change the VIN though. Do the newer OSes change the pinouts or something? Or can't talk to the old ABS/SRS?
  7. #67
    Banned
    Mar 2022
    Indiana
    4,289
    Liability it's safety equipment. They don't want people swapping modules on their own without the right tools to initialize and verify.
  8. #68
    Oct 2004
    708
    Swapping vins is no problem, but it is my understanding that the best OS or PCM swap with that model car will still end up with everything but ASR working. I can't personally verify this, but that seems to be the best case scenario, and requires a lot of work.
  9. #69
    Banned
    Mar 2022
    Indiana
    4,289
    I can flash a flex OS, or swap ECU's, but my VIN isn't allowed to be put in due to the model year. That's about the extent of things I know to try, so I gave up.
  10. #70
    Aug 2024
    Texas
    174
    I have the wideband connected to the pro link setup through can bus. It works on the gauge and every time I repoll for parameters it freezes. is this the most common way to hook this up?
  11. #71
    Banned
    Mar 2022
    Indiana
    4,289
    CAN doesn't work on your ECU. Have to have a wideband gauge that outputs analog and use the pro link cable. Hopefully you have MPVI3 so that the pro feature set is included. If MPVI2/2+ might as well output the analog to the A/C pressure or EGR sensor. There's also serial-usb.
    https://www.hptuners.com/product/pro-link-plus/
  12. #72
    Oct 2004
    708
    There are lots of things you can't do with just hpt software. The open source gen 3 stuff available fills in the blanks. In your case, however, after swapping the vin to a different OS, I'm not sure if hpt licensing would be compatible. Some people end up just using hpt for logging and make their actual tuning changes with other software when this becomes a problem.
  13. #73
    Aug 2024
    Texas
    174
    ok ill give that a try
  14. #74
    Banned
    Mar 2022
    Indiana
    4,289
    Which model wideband?
  15. #75
    Banned
    Mar 2022
    Indiana
    4,289
    Quote Originally Posted by gametech View Post
    Figured it would be something like that. Thanks for looking into it for me, though
  16. #76
    Aug 2024
    Texas
    174
    AEM 30-0300 X-Series Wideband UEGO AFR Sensor Controller Gauge, yes I have the mpvi3
  17. #77
    Banned
    Mar 2022
    Indiana
    4,289
    Good. Just checking you didn't have the CAN only model.
  18. #78
    Aug 2024
    Texas
    174
    Runs awesome the added timing made a big leap in power; however, it still leaves from a stop like a Buick lesabre after about a few mph it kicks in the power like something is holding it back. I did a few pulls from a dead stop. Also noticed on the engine side the drivetrain abuse mode is at 1 mph isn't it supposed to be 255?
  19. #79
    Banned
    Mar 2022
    Indiana
    4,289
    What does the wideband gauge indicate visually during WOT?
  20. #80
    Aug 2024
    Texas
    174
    from a stop or anywhere?
