Hello, my vehicle is a 98 Sonoma with a 383 sbc 24X with 0411 running it. It has a single plane with Holley 4150 tb and a rather large cam (XR288HR). The truck runs pretty good but I cant get the idle to stabilize, there are absolutely no vacuum leaks first off. Ive been messing with the running airflow tables, idle screw and iac, attempting to stabilize the idle. It just wont seem to pick a spot and stay there its almost as if ignition timing or some other factor is controlling it. It will start normally when cold with 310 steps then work its way down but usually it will settle then keep dropping to 0 then the idle maintains. I close the throttle screw and the steps come back up to about 110 then settle at 40-60 then drops to 0 again. Its almost like chasing its tail. I cant get it to pick a spot and stay there, this isnt a rapid fluctuation either it takes several minutes to go up and down. Thanks
