Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 80
Thread: EGR Enable not visible P59 ECU
    Sep 2009
    1,150
    Quote Originally Posted by ns158sl View Post
    Wait. 2005's had an EGR? I thought they were done away in 01?
    The EGR code is still in the PCM. I have it Enabled in my 2005 P59 running a L31 350 based engine for the same reason to log data using the 0-5V input. In my case it is fuel pressure I am logging. The factory 2005 350 setup had it disabled and factory EGR block off plates/caps on the intake manifold and exhaust manifold. Some of the 4.3Ls running on P59s had EGR until much later, probably CA spec. Express vans had EGR with the P59 through 2003 on the 2500 and 3500s with 4.8s and 6.0s too.
    SoCal
    1,851
    Quote Originally Posted by abc View Post
    aaron, why is this the way it is? Is it as simple as having an old version of the HPT sofware? Did they remove the option due to regulations?
    Yes. Exactly as you stated. That's why I run the older software.
    May 2014
    USA
    625
    For the newer vehicles that need internet connection to "phone home" to even open tune files, the older versions are already getting blocked, forcing you to update to one of the last few stable major versions. It seems that so far, these older PCMs are safe from all of that, but who knows what the future will bring.
    May 2024
    Can anyone help me out and enable the EGR tab on my tune and scanner i haver version 5.0.4. I did the training but still dont see the enable disable. i have a LQ4 6.0 with BTR stage 2 NSR cam
    Jul 2007
    Elkhart, Texas
    Quote Originally Posted by luckiestreet View Post
    You're not going to see it. HP Tuners stance is they cannot allow any emissions tampering and will tell you to "get a prolink" or use external inputs. You might get lucky and find someone that has an old version that can still do this, but it appears that as time goes on, this will be a "thing of the past". Good luck! (I have 5.0 and can't turn it on, had HP tuners since 2006).
  6. #26
    SoCal
    1,851
    Sorry just saw your post.
    Carlos w LQ4 P01 10-24-2024 EGR ENABLED.hpt
  7. #27
    Oct 2024
    EGR Enable
    Could some kind soul enable my EGR for me.
    Thank you very much.
    2001 2500hd no egr no ltft enabled ADDED BLUECAT pe and other minor adjustments.hpt
  8. #28
    SoCal
    1,851
  9. #29
    Nov 2024
    6
    Hi everyone. Can I get some help enabling the egr in my sons truck tune? I made the mistake using the computer to look up tuning info and it must have updated and made me update my hp tuners to 5.0.4. Now I can't re-enable the egr on his tune to use his afr for wideband tuning. Any help would be greatly appreciated.
    Thanks.
    Intake exhaust stock curves..hpt
  10. #30
    May 2014
    USA
    625
    Quote Originally Posted by Sqwrly1 View Post
    Thanks.
  11. #31
    Nov 2024
    6
    Thank you
  12. #32
    Jul 2023
    3
    Any chance I can get EGR enabled in this tune file? I tried loading an older version of vcm to enable it, but I'm using an MPVI3 which isn't compatible with the older software. Thanks
    2000 Sierra 4.8l gt500 inj.hpt
  13. #33
    SoCal
    1,851
    Quote Originally Posted by sprayed View Post
    2000 Sierra 4.8l gt500 inj EGR ENABLED.hpt
  14. #34
    Potential Tuner SilveradoQS's Avatar
    Oct 2018
    EGR enable help
    Would anyone be able to turn on my egr? AEM 30-0300 wired into pcm. Any help will be greatly appreciated, 2003 Silverado 6.0 36lbs injectors, long tube , summit 210 heads, summit towing cam. 2003 Silverado no egr 11-5-24.hpt
  15. #35
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    931
    Quote Originally Posted by SilveradoQS View Post
  16. #36
    Oct 2018
    Thank you dhoagland! I owe you a cold one!
  17. #37
    Jul 2023
    3
    Thank you sir!
  18. #38
    I need EGR enable on 1998 Camaro with 411 PCM
    Here is my tune file.
    Need EGR enable for 30-0300 wideband.
    The wideband works but I have zero voltage in my hp tuner scanner.
    Please help.
    Nov 10 1998 Camaro with 411 PCM need EGR enable.hpt
  19. #39
    Jun 2015
    Aubrey TX
    931
    EGR Enable
    Quote Originally Posted by slarsen47 View Post
    Please help.
  20. #40
    Thanks a million!
    Edit: I assume that the change was more than the EGR engage and disengage speeds? Would like to understand the change that I apparently could not do.
