Page 4 of 5 FirstFirst 12345 LastLast
Results 61 to 80 of 85
Thread: Driver Demand Editor: new tool for tuning DBW throttle mapping
  1. #61
    May 2003
    South FL
    1,592
    Quote Originally Posted by CYN_CRVR View Post
    Greg brought to my attention that HP Tuners does not yet support the Transmission Current Gear pids for at least one of the latest ECMs, so I updated the app to handle this scenario. But instead of just ignoring the transmission gear, I implemented an approach that automatically identifies the current gear based on the ratio of the vehicle speed to the engine rpm.
    It uses kernel density estimation on the ratios to assign a transmission gear. The attached graph is an example from a real log. Think of the density estimate as a continuous version of a histogram. This log contained the most 4th gear data since its peak is the highest, and the least 6th gear data since its peak is lowest. The vertical blue dotted lines mark the ratio values identified as a transmission gear peak, and the horizontal red dashed line is an adaptive floor value, below which any peaks are ignored. Each datalog record is then assigned to the transmission gear whose ratio is closest to it. There is spread around the peaks because tire rolling diameter and traction are not fixed values, plus transitions occur during gear shifts.
    You can pull the Trans Current Gear from the TCM for most Gen V stuff with the T87 or T93 as a vehicle specific PID (single blue arrow mode lol). Not sure about Global B though.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
  2. #62
    Tuning Addict
    7,172
    That was global a and global b. The last one I did wouldn't even show an option for trans gear. Had to get a couple of different hpt guys involved to add in the channel and even then it didn't work until the trans was unlocked. That one really sucked.
    ~Greg Huggins~
  3. #63
    Tuner CYN_CRVR's Avatar
    Jul 2023
    Los Angeles
    107
    Would it be at all possible to go back to a slightly larger file size load capability? HPT only allows you to zoom in at 10 mins and then it jumps to 30 mins. Would be nice if it went in 10 min increments, but that just makes too much sense, right? The tool works up to about 25ish or 22ish mins worth of logging time. Only if it's possible please
    Are you remembering to disable the "Interpolate Data Gaps" option when you export your logs from VCM Scanner?
    The last big log I recorded included 56 parameters for a duration of 57 minutes, and it's only 42 MB when exporting to CSV with interpolation disabled.
    Also, keep in mind the app only requires 4 or 5 parameters. After exporting to CSV, if you open it in Excel and delete half the columns, the resulting file will be approximately half the size of the original.
  4. #64
    May 2024
    200
    Hello, this is awsome work! Im having some trubble tho, when using the online editor i can?t generate new tables, just says error, but the graphs and all generates properly.. And when using the local install it says that the driver demand tables are missing axises? (Also note to any in EU, if your locale is set to use "," as a decimal seperator, the HPT export will be wrong... that took a few houres to find out)
    L83 E92A 2017+
    drive_no_stft_pedal_tune.hpl
    Ford_Ranchero_5.3_6L80_Final V5.hpt
  5. #65
    Jul 2023
    Los Angeles
    107
    Quote Originally Posted by tonn0297 View Post
    It's working for me. What are you pasting into the text box on the input tab? Upload a *.txt file of those contents here, plus a screenshot of the local install error message.
  6. #66
    Tuning Addict
    7,172
    Yeppers I have a lot of channels as you've seen and I get right around 25 mins of downloadable logged data that it will let me enter. I wish it would allow 31 or 32 mins without having to delete everything every time, but if it's not possible then it's not possible. The 10 min scanner breakpoint is too short then it won't allow the 30 min scanner breakpoint. Unless there's a way to change that in the scanner itself?
    ~Greg Huggins~
  7. #67
    May 2024
    200
    i have no idea what changed, but its working now... I think its the locale messing with the import of the table.... like decimal and number seperators
  8. #68
    Jul 2023
    Los Angeles
    107
    I just bumped the max file size up from 64 to 85 MB, which should put you over the 30-minute mark. Let me know if you start seeing that gray freeze screen again, though.
  9. #69
    Feb 2022
    Washington State
    60
    I read that you were paying for this out of your own pocket and I wanted to offer some fast compute and storage for this project. I haven't tried using this yet but I can provide a host dedicated to the cause. I think this is an awesome project.
  10. #70
    Tuning Addict
    7,172
    Thank You. I think a lot of that may have been from the computer I was using. It would still do it even with the 64 file size. Got a nice computer now and doesn't seem to be an issue. As always, thank you.
    ~Greg Huggins~
  11. #71
    Jul 2023
    Los Angeles
    107
    Quote Originally Posted by chadtunes View Post
    I appreciate the offer. I'm currently using the free version of shinyapps.io (https://www.shinyapps.io/), so no cost to me, but it's why there are fairly low limits on RAM and monthly active hours. Any self-hosted alternative would have to run Shiny Server (https://posit.co/products/open-source/shiny-server/) in order to deploy these types of apps. Go ahead and try out the app first, then if you want to discuss further feel free to DM me.
  12. #72
    May 2023
    Kyiv, Ukraine
    77
    Thanks a lot for this handy tool! I did all the steps, but after I export the CSV from the system I get all the columns data stuffed into the first one. By any chance did you encounter this behavior?
  13. #73
    Jul 2023
    Los Angeles
    107
    Quote Originally Posted by Roland_Price View Post
    This is a regional settings issue; see posts 50-53 in this thread.
    I bet if I add a tab-separated values (tsv) format export option, it would solve this issue for international users. I can look into this over the weekend.
  14. #74
    May 2023
    Kyiv, Ukraine
    77
    Yeah, that makes sense, I always forget that could be an issue. Thanks for the tip, I'll switch to the US and try again
  15. #75
    Tuning Addict
    7,172
    I don't know if any changes have been made since this morning or if it's just the host site, but it will load the logs fine, but the second it sees the DD table and goes to run its calculations it grey screens.
    ~Greg Huggins~
  16. #76
    Jan 2025
    Hi I just watched your video and it all seems quite self explanatory, except for gathering the initial log file. Do you drive the car/truck as hard as possible with multiple WOT runs OR do you drive as if were a daily "around town" drive?
    Thanks for creating this tool, its awesome.
  17. #77
    Jul 2023
    Los Angeles
    107
    Quote Originally Posted by Johann View Post
    The 'Documentation' tab speaks to this a bit, so definitely read what's there. When I log for this app, I do a series of smooth throttle roll-ons in different gears and different RPM ranges to try to fill in as much of the driver demand pedal-vs-speed matrix as possible. Cruising at steady throttle for extended periods isn't beneficial for this app, and doing full WOT pulls as if you're on a dyno isn't particularly beneficial either, so you're aiming for something in between.
  18. #78
    Jan 2025
    Ah fantastic. This is exactly the explanation I was hoping for, it makes perfect sense. Thanks so much for your swift reply!!
  19. #79
    Feb 2025
    Apologies if this was already mentioned, does this support DD tables with axle torque values? Or this this only for engine torque tables?
  20. #80
    Jul 2023
    Los Angeles
    107
    Quote Originally Posted by BFRITZEL3141 View Post
    Yes, it works with both axle torque and engine torque tables.
