Hi All,
Wanted to see if this is isolated to my MPVI3 or not and see if there are any resolutions.
Intermittently, many of the channels I typically scan for my ZL1 will disappear when I hit the record button. Like the channels aren't available on the car.
I'm noticing this primarily after I scan a log, make a few changes, and then flash them to the car, turn off the car, then go key on/car off, then try to reconnect the scanner and record. Usually when this happens, if I unplug the MPVI3, and unplug the USB cable, then reconnect, it will usually work as expected.
I can always open a support ticket I suppose, but wanted to see if this is a common problem or not.
