Results 1 to 9 of 9
Thread: Global B MAF Scaling procedure
    For those who started tuning these new platforms how did you get to disable speed density?
    So on the Gen5 :-
    1-DFCO, Disable Deceleration Fuel Cutoff in tables 2290 & 2291
    2-Engine , Fuel Turn off COT ; disable table 200
    3-Fuel , O2 sensors, disabling Open loop ; O2 Readiness Table 2529
    and finally Disabling speed density through disabling dynamic air flow! tables 3003 & 3033
    The thing is on Gen 5 we can disable speed density but on Global B "Or let me say on Gen 5.5" you do not have these tables for Dynamic air anymore
    Any thoughts?
    Tuning Addict
    7,172
    Just dial in the MAF and VE at the same time in normal closed/open loop operation. You can kill dfco, but don't go open loop. MAF is cake walk compared to the hpt VE editor If you're adding boost you'll need to change the max load settings for the NN then the VE tables will update for the added pressure ratio.
    ~Greg Huggins~
    Appreciate your response but it's too much to go through the VE and the NN stuff right now while I am just running bolt-ons on my 2022 5.3 truck. scaling the MAF and working on spark and trans tuning is what I am doing at the moment.
    is there a correct way or different approach to dial in the MAF only on these Global B trucks & SUV's? the Old Gen's are straight forward!
    Tuning Addict
    7,172
    These guys can be touchy and have a lot of codes that can be set from map/maf/throttle correlation. If you're having to adjust the MAF then it might require you to adjust the VE. I would log for VE corrections just to be sure it's not way out. You can also log the VE correction factor as a channel to see how bad things are currently out, but basically the VE and MAF need to stay pretty close. You can try to dial in just the MAF and you may be just fine. I would just keep an eye on the correction factor.
    ~Greg Huggins~
    5BA8
    5,462
    I'm with Greg on this one. You can't "MAF only" tune these things. The Neural Network trainer is a pain at first but it must be done. If you're bolt on only and you're trying to dial in the MAF table to get the trims closer, I wouldn't worry about it unless it's setting a code or codes.
    email=[email protected]
    What would you log for VE correction, and how could do same time? Currently i'm not doing much just a CAI but want to get used to doing this for when i do my cam, intake and exhaust
    when you log the VE correction which I am doing now what do you do with it then? I have the log and the numbers but not sure what to actually do with them. And in regards to the MAF only can you just set the min range, HL to say 8000rpm to disable NN and run on MAF only?
    Oct 2016
    Poland
    2,038
    Really need to adjust NN in Global B every single time. Adjusting MAF only is not enough - not the same as Global A
    I.am global A so how do I do the MAF and NN/VE in global A? Can I do MAF and NN separately? Everybody seems to say do both together but never says how
