Results 1 to 6 of 6
Thread: LLY mpg tune
    Oct 2019
    PNW
    13
    LLY mpg tune
    looking for an mpg tune for a stock 2004.5 lly with a mouthpiece. I also have an egt gauge. Im running basically a 20/20 tune but I am looking for a little more fuel economy as I daily drive it. i get 16.5 mpg on a good tank. i had a hot tune that got 18mpg but I had to be super easy on it or else it would throw me into a 2000rpm limp mode. looking for something in the middle. appreciate it guys.
    Nov 2023
    n/a
    78
    would you be willing to post up the ones you got?
    Jan 2006
    DFW
    261
    Post the tune you are running and the stock one. I have been playing with mine lately trying to gain a little MPG with the 6 speed swap I did. Desired boost plays a lot in the cruise areas for economy. Playing with Injection Timing I feel like I have gained a little as well.
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
    Oct 2019
    PNW
    13
    Quote Originally Posted by SUTTERERMAN85 View Post
    LLY tow tune 8-26.hptFULL LLY STOCK TUNE.hptLLY HOT TUNE TP .85 to 2400rpm tire size.hpt
    here are the 3 tunes. The tow tune is the one Im running now, and the hot tune is the one that gives me good milage until i throw it in limp mode
    Jan 2006
    DFW
    261
    Have you checked the milage or are you going by what the gauge cluster says? Im assuming that you have a stock trans and that hot tune is way too much for it. You will only be able to get so much out of these for milage. Best things that you can do is slow down and drive reasonable. I have also found to keep the desired boost low in the cruise areas. What size tires are you running and lift at all?
    2010 CTS-V
    2015 Denali
    Advanced Tuner omega_5's Avatar
    Aug 2005
    Maidstone, SK
    489
    The easiest way to get max MPG is to take a log on a highway drive; 95-115km/h (60-70mph).
    Put the bulk of that area back to stock values. Stock fueling. Stock timing. Stock boost. Stock rail.
    From there, pull a bit of rail pressure. I start with copying the values from 400rpm lower, then smooth to the higher logged rpm range.
    Then pull boost until you start to ride along the 1.25 lambda range.
    Take a few sample runs on timing. Some truck like more. Some like less.
    I've found the newer trucks like timing pulled by 1-2*. The older ones like a bit added.
    On a Duramax, you should be able to get an easy 23mpg highway truck.
