I've been working on my tune now and am pretty happy with the way the car runs so far. I have a LS2 6.0L with 232/236 .595/.595, CAI, ported TB and heads, 3000 stall, exhaust and 3.73 gears.
I have tuned on a dyno with a wideband but only made basic changes to PE and adjusted the high/low timing tables to not produce knock and where they made most HP and TQ. So far car runs great! Could have better mid range I think.
In hindsight, I should have nailed the VE, MAF, and base timing and base airflow before the dyno - but I got a super deal.
Now, I that have updated and fine tuned idle airflow and my VE table and have 2 questions.
1) How do I tune the MAF high and low? Can I do this via recorded histo data? (my wideband is several hours away)
2) On the dyno I adjust hot/cold timing without touching the base timing which was totally stock. How do I check WOT timing using the scanner tool? and how do I choose to modify the base timing tables? I have been trying different #'s based on highest produced vacuum on MAP sensor at idle.
I believe once I've nailed this down, I would have an overall better driving car. Right now, it's fast at WOT only!
