Results 1 to 3 of 3
Thread: Tune request for a 2007 2.4L LE5 With updated Injectors
    Oct 2008
    Mebane NC
    477
    Have a 2007 HHR with a 2.4l throwing a P1174. Would like to up date injectors, need to get the injector data for the new injectors or any factory that will work as a replacement.
    Dennis
    2,767
    I don't know that P1174 is a real code for that engine. Internet leads that to a bank to bank imbalance on fuel trims and you only have 1 bank. Have you confirmed that code with the service manual for that particular vehicle? Beyond that what injectors are you using?
    Oct 2008
    Mebane NC
    477
    Have a TSB from GM covering that very issue. 08-06-04-001
    Models: 2006-2007 Chevrolet Cobalt, HHR
    2007 Pontiac G5, G6
    2006-2007 Saturn ION
    with 2.4L Engine (VIN B, P - RPO LE5)
    Condition
    Some customers may comment on the check engine light being illuminated.
    A scan tool may reveal DTC P0171, P0300 or P1174 set as current or in history.
    Cause
    This condition may be caused by the plugging of one or more of the injector director plate orifices which results in a lean condition.
    Correction
    Important: This condition cannot be corrected by cleaning the injector(s).
    Perform an injector balance test using the Active Fuel Injector Tester (AFIT), CH-47976. Refer to the Fuel Injector Diagnosis (w/CH47976) procedure in SI. If any injector is identified as having a lean condition, replace all four injectors with the revised injectors. After installing the new injectors, reprogram the ECM with updated calibration files using the TIS2WEB Service Programming System (SPS) application. There are two calibration part numbers that are valid for "Engine Operation". Select the part number with the description that reads for vehicles with second design injector. The injector has a dark blue overmold color for this repair.
    Important: The fuel injectors must be replaced and the new calibration files must be installed to ensure a complete repair. Failure to perform both repairs will result in the customer returning with the same condition.
    If a vehicle returns with the same condition after having this repair performed, the technician should first verify that the complete repair was performed before continuing with SI diagnostics.
    Parts Information
    Part Number
    Description
    Qty
    12602480
    Injector, Fuel
    4
    Warranty Information
    Important: For claims to be paid, injector balance test results must be recorded on the repair order.
