Hello,
Need some help here!
After installing BTR Truck Norris CAM on my 2017 RAM 1500 5.7L, truck no longer idles.
MDS and muffler delete - other than that, stock!
Any help is highly appreciated!
Attached tune and log.
Hello,
So it just starts and then dies?
"1MEAN16" Silver/Black 2016 Ram CCSB (4592lbs) NA 398ci Stroker
+6cc Mahle Dome Pistons w/ 13.1/1 Compression on E85
Forged 4.08" Stroke Crank, 224cc AFR Heads w/ Titanium 2.165"/1.65" Valves
Custom Cam 220/238 .611/.589 108.5 LSA 108.5 ICL, 105mm Hellcat TB
Ported Hi-Ram Intake, NXpress Hi-Ram NO2 Plate kit w/125 Shot(4 sec)
Tx Spd 2" Long Tubes, ATI SD 15%UD, Ram TRX K&N CAI
Dual 450 Pumps, Deatschwerks 1000cc Inj, Fuel Cell in Bed
Built 8HP70 w/ 3800 stall/Detroit Tru-Trac/410 Gears
That is correct...
do you have any data log or any codes?
10-17-24.log of ver3.hpl
Codes:
- P1DD2
- P1DF3
Any help is highly apprecited!
i have done the sam btr setup on mine and it will crank but no start. need help badly
shoot me a email
DodgeBoy.
Email / Remote Tune: [email protected]
it doesn't take much to get a Gen3 to fire up and at least idle, tune wise. If it is not firing up then most likely a mechanical issue.
