Thread: Are the HP Tuners Scanner channels available to any OBD2/CANBUS device?
    Jul 2016
    16
    I'm a little confused about what's available on the CANBUS pins on the OBD2 connector. In my case it's a E39A ECU running a GM LFX engine. I want to run a digital dashboard like a Haltech IC7 or AEM CD7, etc. Most dashes offer an "OBD/CANBUS" option that just plugs into the OBD2 port. Can these devices see all of the channels that I can see/find in VCM Suit Scanner or does HP Tuners have some secret sauce allowing more functionality? Are they monitoring the ECU's canbus directly or would they be polling for OBDII PIDs?
    Jul 2020
    VIC Australia
    1,515
    It's a question you need to ask the dash board vendor of your choosing. Some will only support the standard obd PIDs whilst others will support far more. FYI HP tuners aren't doing anything 'special'. Power tune list can bus support for GM. Might be worth flicking them a message to see if your set up is supported. Good luck.
    SoCal
    1,851
    Coming in a little late in the game but I saw this and it made me chuckle. "does HP Tuners have some secret sauce allowing more functionality?"
    HP tuners is only slightly better in terms of the scanner on what can be done with a low level stand alone scan tool. Not a cheapy scan tool but a low level $500 to $700 scanner. You would be floored to see what data I get from GDS2 and the MDI2 module.
    I found out today that the aem dash is a bit of a joke when it comes to the obd2 scanning. The only useful data the aem can see is coolant temp and engine rpm.
