Results 1 to 5 of 5
Thread: Help reducing TM - 07 Silverado 6.0L
    Mar 2007
    13
    I have a NBS 07 Silverado, with the 6 liter VortecMax. I'm trying to either eliminate or reduce torque management at WOT. Attached is my config attempt, and a log. If you look at the log, looks like there's still a significant timing advance drop, and drop in torque output (~30%) during the 1-2 shift.
    I've changed everything I can find/know how to change....is there another param I'm missing somewhere?
    For this truck, some of the options that I've seen mentioned don't seem to be available...unless I'm overlooking them somewhere, like disabling Abuse mode, shortening shift times, etc. All that I was able to find was shift pressure settings, and torque reduction settings.
    405
    3,225
    Look in the Transmission>Torque Management tab. There are a lot of TM tables there to adjust or zero out.
    Mar 2007
    13
    I only see 5 tables there:
    Torque reduction Normal - I changed all values for 1-2 shift to either 0 or 5%
    Torque reduction Performance - ditto
    Torque reduction Downshift - didn't change anything here
    Abuse Mode Torque reduction: I didn't make changes here. The default value is 100% reduction from 2048 rpms and up....I don't think I'm hitting 100% reduction
    Abuse ModeReduction duration: Didn't make any changes. The X axis is Transmission Oil Temp. Y axis doesn't have a label. Almost all values are 0.6 for normal ranges.
    So....should I really be zeroing out these last two tables? Doesn't seem like they're being activated - doesn't seem like it would matter.
    The only other options on the Transmission TM tab are:
    General
    - Diff scor (default disabled)
    Stall Torque Mgmt
    - Enable RPM (2000 rpm)
    - Disable RPM (1600 rpm)
    TCC Limit
    - Tq Reduction (disabled)
    - Max Torque (6045 ft lb)
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Abuse mode is when you are "brake torquing" the engine. FYI
    Always Support Our Troops!
    Advanced Tuner gman4dx266's Avatar
    Jun 2006
    Cape Coral, FL
    860
    Quote Originally Posted by EC_Tune
    ..."brake torquing" the engine...
    *drools*
    "...Whats that smell?"
