Page 1 of 5 12345 LastLast
Results 1 to 20 of 90
Thread: What to look for in a scan?
    Advanced Tuner Timonator's Avatar
    NW,Il
    206
    I'm a total noob to tuning.I have 99 TA that have installed headers,cam,heads,pulley,ls6 intake on.I've recorded a couple of scans and wanted to know what trouble areas to look for so I don't hurt my engine.The tune in it now is tolerable.But I know it isn't correct.
    Супер Модератор EC_Tune's Avatar
    Apr 2003
    Almost 2000 feet.
    7,876
    Well, it's significantly lean virtually everywhere 13-16% in Scan 2 but in the March 30-07 it looks (STFT wise) Rich.
    Always Support Our Troops!
    NW,Il
    206
    Quote Originally Posted by EC_Tune
    Scan 2 was a longer drive.the march 30-07 scan was just a trip around the block.How can you tell when it's lean?
    NW,Il
    206
    You mean the LTFTs are rich,right?
    Apr 2003
    Almost 2000 feet.
    7,876
    LTFT's that are + are lean, - LTFT's mean it's richer.
    NW,Il
    206
    I got it.How hard is it to richen it up?
    28,313
    Quote Originally Posted by Timonator
    usually a simple copy & paste will work as long as you've filtered out bad info or cells.
    NW,Il
    206
    This is my most recent scan.From what i can tell I think it's telling me that I need injectors.What do you think?
    Apr 2003
    Almost 2000 feet.
    7,876
    MUCH better near idle but everywhere around it is still lean.
    NW,Il
    206
    How do I richen it up?Or do I have to buy injectors?
    Apr 2003
    Almost 2000 feet.
    7,876
    You are at that decision point. However without a wideband you have no idea how rich/lean things are at WOT. It may be rich for all we know. If it's rich, then you have enough injector (for now ).
    NW,Il
    206
    I'm guessing it's lean at high rpm because according to the scan It goes lean and the injector duty cycle is maxed at high rpm.Can I richen up the fuel trim cells?Will that help?If Iever get a wide band do I need 2,1 for each side?What would you do?
    Apr 2003
    Almost 2000 feet.
    7,876
    I wouldn't assume it's rich or lean. Stock narrowband sensors are highly *un-reliable*.
    I have seen 11.5 with the wideband and NB's were 820mv
    I have also seen 13.5 with the wideband and NB's were 960mv
    Now which are you going to believe?
    NW,Il
    206
    I guess I'm going to wait till I can get a wideband.Will it work with just 1 or do I need 2?
    NW,Il
    206
    Apr 2003
    Almost 2000 feet.
    7,876
    No reason to have two and yes the innovate will work.
    NW,Il
    206
    Thanks for the help.I'll be back after I get the wideband.
    NW,Il
    206
    Oh yea,I was also wondering why the KR kicks in every so often.Is that normal?
    Feb 2007
    Bentonville, Ar
    8
    This is just the sensor can you get by with wiring the sensor direct to HPT or do you need to get the display unit also?
    28,313
    you need the sensor and controller...some of the lower priced units have just these two things without the display. But work very well with hpt.
