Results 1 to 20 of 21
Thread: MAF TUNING FILE / First try at tuning
    Oct 2022
    16
    Good morning - Trying to dial my MAF in a little better.. please take a look and let me know what you guys think.. where I may need to adjust. Car is a 2014 Camaro ZL-1 mods: Cold Air Inductions Intake / Headers / Catless 3" exhaust / ID850 Inj / BTR Stage 2 cam / water - meth injection / 2.55 upper pulley / 10% Lower Pulley
    Aug 2024
    IA
    61
    You are gonna want to attach the tune. But it looks like you are in open loop. Not sure that is necessary with this cam. You have a lot of spark correction at idle. You can look at over/underspeed tables to maybe smooth this out.
    Oct 2022
    16
    Here is a copy of the tune file
    5BA8
    5,476
    Horrible idea for that to be your first attempt at tuning. Those by far are the most blown-up engines due to lack of knowledge.
    email=[email protected]
    Oct 2022
    16
    Appreciate that..
    5BA8
    5,476
    You need to take more timing out of it to begin with. And your knock recovery rate is way too high. You're gonna hurt it.
    Oct 2022
    16
    Lets start over. The tune is from another tuner... I've noticed alot of variances in partial throttle so I was going to try to dial the maf in and then work on the VVT table. I took 5* out of total timing over all.
    Oct 2022
    16
    Thank you for bring that up on the timing! I thought I took the 5* out but I did not. As far as the Maf sensor does that look decent?
    North Carolina
    4,859
    The MAF looks close, I tend to get better results 100% SD on a application like this. Just putting that out there.
    The timing looks excessive but I didn't see any knock. But to be fair I didn't track down a stock file to see if the knock sensors have been desensitized to the point they don't work.
    VVE looks like it needs a good bit of work.
    5BA8
    5,476
    I hadn't looked at your data log until you asked how the MAF looked. And now that I have I'm worried for your engine.
    First, you're in open loop and shouldn't be. To determine how well your MAF is dialed in you need to be looking at your trim correction. I don't give a hoot what a wideband says and neither does your car's PCM.
    Second, it looks like you have constant misfires on both banks. Hopefully not due to engine damage already. As I stated earlier, these engines are the #1 engine blown up due to lack of knowledge both by DIY guys and pros alike. I see it all the time.
    North Carolina
    4,859
    The misfires are from his cam. He hasn't addressed the misfire tables for the cam yet. Or doesn't know to do that.
    5BA8
    5,476
    No. The O2 sensors do not look like a stage 2 cam. I'm not looking at the misfire counters.
    The O2s say it has misfires at idle and well off idle where they should definitely clean up. It 100% has misfires on both banks.
    Example A
    And worse on the other side, even higher RPM
    Example B
    That thing should not be looking like this at 3400 rpm even with a stage 10 cam.
    Mar 2022
    Florida
    163
    Example A
    Example B
    Seems like a physical issue to create that reading on the bank2 O2 sensor. I’d look into testing and fix to bring it back in line before further tuning.
    2017 Silverado 3500HD WT 6.0 flex fuel 6L90 6800lbs E78A T43
    --- What am I doing??? Why did I do that??? ---
    Oct 2022
    16
    Welp all of that is completely new to me.. I'm a little unsure where to go from there. I've noticed that part throttle driving wasn't the greatest from the tuner so I wanted to work on the MAF and VVE tables but it sounds like I may need to start over completely.
    5BA8
    5,476
    First thing I'd do is a thorough exam of the engine mechanically speaking. Pull and inspect all the plugs. Do a compression and leakdown test. When you put the plugs back in make sure to get a good "snap" on both the coil and the plug end. This is the #1 cause by far of ignition misfires. People just don't get the wires fully seated. Second cause is cracked plugs. So while you have them out might want to just replace them.
    If your compression and leakdown tests show you have an issue with a cylinder or two, then it's time for further inspection, borescope, tear down, etc.
    Oct 2022
    16
    I'll work on that this weekend. I know we did replace all plugs when we installed the cam so it is a possibility that some of the wires are not seated all the way. As far as how the car runs.. it feels great so I wouldn't thing the motor itself is hurt.
    5BA8
    5,476
    Quote Originally Posted by Jtouch View Post
    First question is, what wires are on the car? I don't recommend anything but AC Delco wires. No MSD, etc.
    First thing I'd do is go over the wires. Give each one a decent pull from the spark plug end. Try to pull them off the plugs. If they're snapped on correctly you should be able to pull on the pretty good without them coming off the plugs. If one or more isn't seated you should be able to pull it off the plug fairly easy.
    North Carolina
    4,859
    The misfire diag still needs to be addressed for the cam.
    Advanced Tuner JayRolla's Avatar
    Mar 2021
    359
    For what its worth I have had good luck with Granatelli Ceramics and even some cheaper Accel Ceramics. But I used to only run AC Delco or OEM wires on all my other cars till I came to the LS world.
    2013 CTS-V Coupe M6 - 2" Headers, 3" x-mid pipes, stock mufflers, Airaid intake w/green filter, ID1050X injectors, DSX flex fuel kit, DMS 2g under hood tank, ZZP pump, reinforced brick, 3/4" lines, AFCO HX, Griptec 2.4" pulley, solid isolator, 100mm idler, MM mild catch can, AEM 30-0334 wbo2, 600whp/630wtq on e85
    Oct 2022
    16
    I'll take a look at those as well.. I did not replace those since the car only had 30K miles on it but might be something that I need to take a look at to. I'm hoping it's just a plug that's not connected all the way.
