Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
Thread: Injection timing truck norris cam LY6 e38
  1. #41
    Mar 2009
    Andover, MN
    825
    Quote Originally Posted by Balakayt. View Post
    The more i learn the more there is to learn lol. Anyone know of a program i can use to get a Gen 5 BIN file off my truck by chance? i have a mongoose GM 2 cable.
    poke around pcmhacker. there is a D/L there.
  2. #42
    Mar 2022
    32
    You heard it here first:
    https://youtu.be/FmdJOOUUqQg
    https://youtu.be/viLlBZVbeag
    Hats off to Verlon!
    Hats off to you Cringer, the new tool works flawlessly and really opened my eyes to how far off my EOIT really is on my 5.3 Tahoe with Chopacabra. Just a couple small tweaks and my idle and part throttle is so much better. The best part is the smell at idle is almost completely gone.
  3. #43
    Senior Tuner Cringer's Avatar
    Aug 2021
    1,111
    Quote Originally Posted by Tech1340 View Post
    That is great to hear! Do you happen to have the cam specs with valve timing events for that cam?
    <<< A standard approach will give you standard results >>>
    My Free Tuning Software:
    MAF Assistant
    EOIT Assistant
  4. #44
    Tuner Balakayt.'s Avatar
    Jul 2024
    DFW, Texas
    66
    What are yall using for filter on the EOIT PE histogram?
  5. #45
    Aug 2021
    1,111
    Logging IPW? I just use where Commanded EQ < 1.0 for PE. And Commanded EQ = 1.0 for CL.
    MAF Assistant
    EOIT Assistant
  6. #46
    Jul 2024
    DFW, Texas
    66
    Perfect. I assumed that was what i needed but just wanted to make sure. i started second guessing myself. thanks.
  7. #47
    Mar 2022
    32
    It's similar to Truck Norris. I have the specs @ .050 and used the calculator you provided to find the following @ .006. I did have to round to the next degree up because they all calculated as half degrees.
    EVO:68
    EVC:28
    IVO:28
    IVC:60
  8. #48
    Mar 2022
    Olathe Ks
    137
    What did you actually end up with your EOIT Table ???
  9. #49
    Sep 2024
    East Tennessee
    10
    I have not ran the truck since cringers suggested settings I?ll update in the future.
  10. #50
    Aug 2024
    IA
    61
    Thanks for the work on this, Cringer and Verlon! Excited to learn about this and give it a shot. Also, LOL at the "So you bought a Truck Norris cam?" button in the EOIT tool
  11. #51
    Sep 2024
    East Tennessee
    10
    truck ran good wit the new tune cringer unfortunately I think my ecm is also fried{like my tcm} got the new tcm in and programed fired up the truck and when everything started getting up to temp it freaked out and lost communications to all modules and died cleared codes and fired it back up and it dies in reduced engine power. has anyone else expirenced a dead e38 but only when it warms up
  12. #52
    Sep 2024
    East Tennessee
    10
    in a slump right now guys the build has been tough on me and ive been so excited to learn to tune but all these setbacks killing me thanks for the help on EOIT cringer your settings definitely cleans up the smell
  13. #53
    Sep 2021
    Kentucky
    1,839
    May be odd but ive seen people put the wrong battery on with the terminals opposite and the positive hitting a ground on the firewall killing several electronics.
  14. #54
    Sep 2021
    Kentucky
    1,839
    Another recent one was a shorted transfer case actuator.
  15. #55
    Sep 2024
    East Tennessee
    10
    definitely i was installing my dipstick and accidently hit the starter bending it for headers... it is a headache i hope the ecm is my last to replace
  16. #56
    Sep 2021
    Kentucky
    1,839
    I did just arc a whole side of an exhaust on a starter. Luckily all is good with the car. Good lesson ill never forget.
  17. #57
    Dec 2022
    29
    Given the input:
    .050" Duration: 212/224
    LSA: 107.5
    ICL: 106
    We calculate:
    ECL: 108.5
    Adv: 1
    Overlap: 3
    Then we calculate the valve events for .050" to be:
    EVO: 40.5
    EVC: 3.5
    IVO: -.5
    IVC: 32.5
    Then we assume the ramp rate for most LS cams to be 25* for opening and closing (50* in total), so we can calculate the .006" duration:
    .060" Duration: 262/274
    Then we calculate the valve events for .006" to be (use the .050" events and add 25* to the opening events and add 25* to the closing events):
    EVO: 66
    EVC: 29
    IVO: 25
    IVC: 58
    Then we find the all important number for end of overlap (don't spray fuel until/after):
    360 + 29 = 389 Boundary degrees
    Assuming you want to zero out the N. ECT table and use use the Boundary table...
    1) 580* Boundary Angle works great for most aftermarket performance cams for high RPM areas (starting from say...4000 or 5000 rpm up to 8000). However, you will need to account for the -7* Intake Cam offset and that means your Boundary will be 587*
    2) For idle RPM, you will need to add your IPW in degrees to 389* to calculate the Boundary. Assuming your IPW is 2.2 ms, at 800 RPM idle, that comes out to 11* IPW in degrees. 389* + 11* + 7* = 407*
    3) For Mid RPMs you will need to blend/interpolate the idle Boundary from 407* to 587*. You will need to experiment here for throttle response, popping, and fuel trims.
    Note:
    The 7 comes from a hidden table that Verlon found relating to OS's that have a variable cam. When the cam is parked, it pulls 7 degrees out.
    If you have an OS that never came with factory variable valve timing, then you can ignore the 7 (assume it is zero).
    Tuning:
    • This is needed since we are assuming a 25* ramp rate.
    • There is also push rod deflection and lifter plunger compression that need to be accounted for.
    • Experiment by moving the Boundary lower (sooner SOI) and higher (later SOI)
      • CL you want lower fuel trims, no fuel smell, good throttle response for sharp pedal movements, and no popping
      • PE you want richer EQ on the wideband and a faster timeslip!
    https://www.summitracing.com/newsand...ing-calculator
    Here is an example of what I mean. This is a starting point for you and by no means to be considered perfect/done/tuned!
    Am I correct in assuming that all of those numbers would be with in at least standard deviation or close on a 5.3 version with same cam?
  18. #58
    Aug 2021
    1,111
    Quote Originally Posted by Xguardian View Post
    The cam events are the same no matter the engine displacement. You may still have to experiment to to find the best injection timing to utilize the peak piston velocity. YMMV.
    MAF Assistant
    EOIT Assistant
