Results 1 to 11 of 11
Thread: 2024 SEA-DOO 325 there is something new and Today is the day
    Advanced Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    245
    is going to be legendary
    Tuner JT_alex's Avatar
    Mar 2023
    SPAIN
    59
    "Legendary" it would be if unlocking could be done without sending the ECU,even so ,its a great step.There is no info about using and updating stuff with buds, will it relock the ecu or not?
    Oct 2007
    Crawfordville, FL
    2,583
    Quote Originally Posted by JT_alex View Post
    You can 100% use BUDS and it will not relock the ECU.
    Eric Brooks
    HP Tuners, LLC
    Sep 2022
    WorldWide
    245
    Quote Originally Posted by Eric@HPTuners View Post
    good job eric. question are we able to log the oem 02 sensor or have to be like before
    Mar 2023
    SPAIN
    59
    Quote Originally Posted by RUTHLESS View Post
    Good question!!!I think It won't be a problem,maptuner can do the log on OEM O2 sensor.
    Mar 2023
    SPAIN
    59
    ok,great.Another question:Reading this protocol will be compatible with other tools, or its LOCKED only for HPT?
    REGARDS
    Yes, you are able to log the actual lambda value from the wideband sensor.
    According to our Powersports MG1 service, the ECM is not tunable with other tools other than BUDS.
    Sep 2022
    WorldWide
    245
    Quote Originally Posted by jayson@hptuners View Post
    yes, you are able to log the actual lambda value from the wideband sensor.
    According to our powersports mg1 service, the ecm is not tunable with other tools other than buds.
    thank you
    Oct 2007
    Crawfordville, FL
    2,583
    Yes, commanded and actual lambda can be logged.
    Eric Brooks
    HP Tuners, LLC
    What is involved getting the ECU out on a 2024 RXTX? My ski is in storage and just getting the cover off right now is tough to even look.
    Jan 2022
    Galloway NJ
    183
    Quote Originally Posted by whittlebeast View Post
    four 8mm screws that are a PITA it remove. LOL
    then it just unclips from the top of the airbox.
