Results 1 to 12 of 12
Thread: Add more throttle on idle.
    What is controlling final throttle position on idle?
    Cranking table controls initial position.
    I understand that VT basically controls the timing.
    I understand MAF with VE interprets airflow and decides on injection pulse and airflow model.
    Messing with either messes with fuel at the same time.
    Throttle body scalar doesn't do anything as far as I can tell.
    Reserve doesn't do much either.
    External load - not sure what it does either.
    Let's say I want to add 10% to idle TPS - how would I go about it?
    2,744
    Why would you want to change idle TP specifically? To get it to idle at a higher RPM? The ECM will try and pull/add timing to maintain RPM and then adjust throttle position. I don't think there is a direct control of throttle position at idle or anywhere else.
    Because sometimes I disagree with what it decided is the best throttle position on idle, some setups require low timing high airflow to idle properly, and I want to know how to get it there.
    May 2003
    South FL
    1,592
    Virtual Torque and Airmass determine calculated torque which in turn the ECU uses to decide how much throttle vs spark to use at idle. You can influence it if you know what you're doing. But unless you have zero pedal torque near 0, you will fight other issues.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    Influences which way?
    More VT = less timing.
    More VE = ?
    May 2003
    South FL
    1,592
    Quote Originally Posted by MoBoost View Post
    More VE = ?
    It all depends. It's been discussed in multiple threads on this forum.
    [email protected]
    snackbartuning.com
    Owner/GM Calibrator
    5BA8
    5,447
    Are we playing a guessing game? No year/make/model, tune file, data log, vehicle mods, nothing.
    What do we get if we win???
    email=[email protected]
    Stock 2014 5.3 silverado with clogged cats and failed lifter.
    Depends how in relation to final throttle position of idle logic?
    Is this a taboo question?
    Tuning Addict
    7,172
    Play with the map side of the torque model then use the airmass model to balance it back out. in particular you either add or take away in the higher load. Needs to be shaped right so as when airmass is increasing torque is staying the same between the two models. There's also cranking airflow - that determines you min air - needs to be about 2 g/s over actual. In all honesty though, if the torque model is right and idle timing is from 7 to 18 degrees then you shouldn't need extra airflow.
    ~Greg Huggins~
    Oct 2014
    Moscow, Russia
    318
    ... some setups require low timing high airflow to idle properly, and I want to know how to get it there.
    Increase torque reserve
    [ECM] 33720
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
