Results 1 to 3 of 3
Thread: HELP not able to go full gas over 4000 rpm
    Apr 2023
    Italy
    50
    I have a LZ4 wirh a e38 pcm with t42 automatic control ) but running with manual gearbox even if the map is for auto, turbo mod everything works fine but suddenly I'm not able to go over 4000 rpm if I put full throttle, while at 50% I'm able to go over . (May be i did a remapping in meanwhile)
    The trans think it is in 1 gear but no PNDR detection
    Help me please I'm getting mad (no error reported)
    Paolo
    Grifun mid engined V6 3500 LZ4 manual trans
    14,067
    The park and neutral rpm limiter is still set to 4,000rpm. Could be that.
    ECM table 12050.
    Apr 2023
    Italy
    50
    Just found the table!!! thanks!!!!! I'll check
    Paolo
