Results 1 to 5 of 5
Thread: 2011 Sierra WT adding cruise control???
    Nov 2024
    Has this been done with Hp tuner?
    I?ve seen threads elsewhere about having to take your truck into GM to have them flash this option. Provided you add all the factory wiring and switches.
    Just curious if you can get into the options to add cruise control to a W/T that never came with one.
    Oct 2014
    Moscow, Russia
    319
    Most likely it has cruise enabled in ECM, but disabled in BCM.
    It can't be done with HPT.
    2011 Cadillac Escalade L94 w/LS3 valves and valve springs
    2,748
    Totally different vehicle but my Kia Soul only needed to swap in the steering wheel with the switches to make cruise control work. But it doesn't have a light in the dash to show the status of CC.
    Nov 2024
    Ok thanks. I kind of figured that. Wonder if you swapped an identical trucks BCM into mine if it would work.
    Oct 2014
    Moscow, Russia
    319
    Post tune file. If I have reversed your ECM OS I will confirm whether cruise is enabled or not.
