Page 119 of 123 FirstFirst ... 1969109115116117118119120121122123 LastLast
Results 2,361 to 2,380 of 2454
Thread: Introduce yourselves here..
  1. #2361
    Nov 2024
    SoCal
    3
    Hi All!
    New to tuning with HP but getting to know where to go with it. My "test bed" is a 55 Bel Air with 06 lq9, 4l80, long tube's and somewhat stock for now. Planning a cam upgrade, lifters, push rods, and springs soon. The car is being massage toward street/show driving. Nothing track related. I've got 40 years of control system troubleshooting and design behind me, but have this project to occupy me and have fun with during "retirement" and chemotherapy.
    I appreciate those with experience sharing their knowledge and look forward to reading and learning all I can from you!
    Happy motoring!
  2. #2362
    Mar 2023
    3
    hey all . im building a 1988 camaro irocz . its got a 5.3 truck bottom end . 243 heads a summit stage 2 turbo cam . trick flow .650 springs an ls7 lifters . a gt45 turbo . my plan is max out the gt45 an be happy with that . i will street drive it a good bit on low boost 6 lbs . anyway im new to the hptuners world i got a 411 ecu says 2000 camaro on outside in marker .i got a wiring harness off ebay . ill be here alot the next few months im sure
  3. #2363
    Nov 2024
    4
    Hi I am James from Sacramento CA. I have tuned several cars on megasquirt/tunerstudio this is my first time using hp tuners. trying to tune 07 chevy uplander with turbocharger.
  4. #2364
    Nov 2024
    3
    Hello my name is Russell from Missouri
    Just recently purchase a 2013 chevy caprice planning on doing some upgrades to it. Also have a 06 Charger and a 09 Chevy Aveo, so I have a few toys.
  5. #2365
    Nov 2024
    Good morning everyone my name is Justin.
    I have recently bought a 2007 F150 with a 5.4 that needed a camshaft and timing components and a few other things. While looking for cams I decided to go with a comp cams (127020) and lock the camp phasers along with a few other things. I really couldn't find anyone that could tune the truck local so I decided to to give tuning a try (we'll see how this journey goes). I also have a S10 that I'm looking do a few upgrades to and tuning will come in handy there too. I look forward to getting the process started.
  6. #2366
    Nov 2024
    Hey guys my name is Kevin. I'm looking for a little help and idk where to go. I need to get in touch with someone who can write a tune for my truck. It's a Ram 1500 2016. I installed long tube header's on it. But now the O2 are registering that's it's got a leak or defective. Obviously they are not. What's happening is it's not heating up quick enough for the parameters in the computer. But anyway if anyone can lead me in a direction of a programmer I'd really appreciate it.
  7. #2367
    Nov 2024
    Creepc in the Houston area, actually Galveston county. Done a few older motor swaps, before obd2. most recent thing going is a 2018 5.3 with 6l80 into my 91 Silverado. What a difference that is. Had to have help getting it to go, had the wrong computer, but Eber got me going. since then, made it a daily driver. See a few things in need to do mechanically, like replacing dod lifters and cam up a bit, and making some changes to trans and torque converter. Hoping I can find the help I need in here without having to embarrass myself by asking questions. When I changed the rear gear from a 2.83 to a 3.73 the tune had to change to get the speedo back, and it changed some other things as well. Still don't like the way it lugs between 40 and 60mph. That is some of my focus for now. Thinking it may be torque converter settings so may play with that a bit. Anyways, HELLO!
  8. #2368
    My name is Jeff.
    I've spent most of my career in road racing. My primary tuning platforms are Hondata, AEM, Haltech and MegaShit.
    This is my first experience with HP Tuner. Within 1 hour I am here signed up on this forum to figure out WTF this program wants from me. I have read through the tutorial and I have learned very little from it.
    I am going to do my best to find the answers from past threads but tuning on this platform seems to be about defining constraints instead of defining VE, Spark and VCT tables in a normal KPA vs RPM on a 2d table. This is the opposite of what I beat into my brain for the last 15 years.
    I am here because I have recently assembled and installed a 6.0L LS. Texas Speed Deleted AFM and VVT Kit.
    Using the downloaded OEM ECU parameters I have disable DOD and set Cam to 0. I have set my injector parameters based off the provided information from them.
    My issues:
    This is my first V8 Tune. Yes, I define this as the first big issue.
    The engine running but STFT are maxxed positive on bank2 and are high but reasonable on bank 1. Black smoke is chugging out the exhaust.
    Normally i would go to the Fuel map and take away the positive STFT percentage from the table and start reeling in the rich condition buuuut, this program doesn't seem to offer this.
    Also, TPS seems to be stuck at 25 26% for some reason. I can not seems to relearn the throttle body or pedal from the Editor or Scanner.
    If anyone is willing to point me to a thread specifically outlining how to change and refine fuel and spark maps i would greatly appreciate it.
    I do have the Tune and the log if anyone is willing to view them.
    Thank you
  9. #2369
    Nov 2024
    Hey everyone .... so my wife and I bought a 2006 grand Cherokee only to find out we were probably silly for being so trusting however since I had me a lemon I went with it. Pulled the motor outside in the winter, you can already see when this is going.. i purchased a hellfire 2.0 cam from FRP reman heads which I ported and polished, high volume oil pump clevite tri metal bearings, stainless long tube headers, AMS lifters mds delete egr gone etc it's a race jeep. I finished this motor a few months ago and spent a month everyday after work til the wee hours getting everything hooked up, long tube's in a jeep ....what was i thinking? It fired right up sounds great then dies. I didn't have the money to pay a tuner at the time. Last night I blew my wife's Buick up trying to get into our building site. She's got to work on Monday and that was our last running vehicle. Does anyone have a tune for this 2006 grand Cherokee. ??? Thank you in advance God Bless
  10. #2370
    Nov 2024
    Leoville, SK
    6
    Hey I am a heavy truck diesel mechanic here in Sask and just got hptuners a while ago to do some tuning on my own and friends vehicles. Very new to tuning so been reading a lot trying to figure these gas and automatic trans tuning out!
  11. #2371
    Potential Tuner s3gpulse's Avatar
    Nov 2024
    Yuma Arizona
    Good afternoon, my name is Chris. Just purchased my first c5 and MPVI3. Looking forward to learning how to tune it with just doing my cam swap. Hoping to learn how to tune correctly and get the car at its best. Thank you and have a great day!
  12. #2372
    Dec 2024
    6
    Hi all! My name is Eric, I?m from Dorchester, Ontario. I just bought Hptuners mpvi3 so that I can hopefully get my lq4 swapped into a 1979 gmc campers special dually and get it running. Very new to all of this so I?m sure I?ll have lots of questions
  13. #2373
    Dec 2024
    Seattle WA
    3
    Hello All,
    Newb here. Wanted to say hello! Ive had HPtuner for a couple years but havent used it for its main purpose I purchased it for. Looking to learn and grow and help out as much as I can.
    Thanks!
  14. #2374
    Dec 2024
    13
    Hello all, names Rudy. Had alot of cruzes and sonics, tuned greatly by Trifecta Performance. But im ready to start tuning myself! Took some HP Academy courses and got an mpvi3. Already tuned one of my cars. Will be around.Thanks!
  15. #2375
    Banned
    Dec 2024
    214
    This playlist can be my intro.
    https://www.youtube.com/watch?v=Jw7M...G_bLLPLggkRWp5
    Eh, what the hell, here's this one too https://www.youtube.com/watch?v=MCP5...UGr7tsnZJbTkSF
  16. #2376
    Nov 2024
    Louisville, ky. Portland
    115
    hello, my name is tom im 58 years old. ive owned many camaros in my days. 1969, 1976, 1986,1992 bunch of chevy trucks. i have this lil truck that i built. its the lm7 bored out. with the 0411 pcm. tuned bye pcmforless and dylan helped me with it. great people. i just want to learn this stuff. i am a small engine mechanic for a mid size city. i work on there z turns stuff like that. thats about it. i love my kids and grand kids and just want to have lil fun. with these things.
    2003 gmc rcrb black.5.3, 4l80e.
  17. #2377
    Dec 2024
    4
    Hello, my name is Jon. I am am industrial maintenance mechanic, and an automotive and motorsports enthusiast. I have always loved anything with an engine, and making them go faster. I have a heavy right foot and like the thrill of fast and loud vehicles. I have wanted to take a dive into tuning modern vehicles, and finally took the leap. Ordered an MPVI3 and PCM unlock for my 2017 Ram 1500 5.7L. I also have a 2007 Grand Cherokee Laredo with the 3.7L that I will eventually be tuning. Happy to be a part of the community and hoping to make some friends and gain some knowledge from you guys along the way.
  18. #2378
    Nov 2024
    9
    Hi I'm Ed. A local truck driver, and gear head. I just had a Ls 362/450 gm crate motor put in my 2000 silverado. My tuner can't get it tuned right, so now I'm on the hunt for answers.
  19. #2379
    May 2024
    8
    what's up everyone my name is Felix. I'm a mechanic and own a 92 300zx N/A unfortunately and a 2020 Camaro 2.0T. I've been around cars all my life and always was to intimidated to try to learn how to tune but I build up some courage and here I am.
  20. #2380
    Dec 2024
    Midland TX
    How it going everyone! Justin here. 27 years as a professional mechanic. Most in Dodge dealerships, went to the aftermarket a few years ago and not looking back.
    I?m a hopeless mopar guy. I really love 2nd gen ram and 2nd gen Dakota. Hoping to learn more about doing my own JTEC tuning and get to a place I can contribute to the knowledge base.
