Results 1 to 2 of 2
Thread: 2018 Chevy 1500 No crank (No Vats option)
    Dec 2024
    Question 2018 Chevy 1500 No crank (No Vats option)
    I have a 2018 1500 that will not crank over, the circuit from the ECU to the starter is good and will crank when jumped via a power probe, and everything appears to be communicating fine.
    I have a code;
    B3902:00 - Incorrect immobilizer identifier received.
    The key turns the cylinder, and you can hear relays activating, and the throttle blips, I went to disable the VATS system but there's not VATS option in the systems tab.
    Thanks for the Help
    Tuner Balakayt.'s Avatar
    Jul 2024
    DFW, Texas
    66
    Did you swap an ECM from a different vehicle into this truck?
